Question about Gateway GM5472 PC Desktop
Do not turn on I change the power supply and still doing nothing
    Genius:
  • 1,288 Answers
Assume you have made the connections on the main atx plug to the motherboard AND the smaller 4 pin Black and yellow wired plug (cpu power).
If the PSU you have just installed was sure to be a good one, then the issue lies with the motherboard or the switch to the power supply on the board (2 pin wire connector labelled PW). Try to remove the connector and then bridge the connection manually with an insulated screwdriver by BRIEFLY touching the 2 pins on the board. If the switch was faulty, this will bypass it and the computer will boot.
If it still will not boot, try removing all non -essential components. leave only 1 stick of ram and the video connection. if it boots, replace each in turn and see which one causes the computer not to boot.
If that fails, examine the board carefully, look closely at the capacitors ( small cylinders) on the board if any are bulging or the top is leaking a rusty coloured crust, the board is dead and will need replacing
Posted on Mar 26, 2011
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
TV stuck in standby
have you looked at power supply as you might have to change the caps on the power supply
Jan 25, 2014 | Bush Industries IDLCD26TV16HD LCD TV
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Mother board powers up when power supply is turned on Does nothing
try your cmos battery make sure it has dust free connection and is securely seated and has plenty of charge
some motherboards cmos batteries are soldered in
hope this 2027.jpghelps
Feb 12, 2012 | Computers & Internet
Hi, i have an "universal box" the ones we use to mobile phones, now when i connect the power , nothing shows "is dead" what to do to repair it ? thanks
universal box is powered via USB port which is normally about 5v... I would recommend you first check the USB cable you are using, try to also check your USB port or change to a different one. Do you get any LED on the box once connected. do you get and USB to serial device listed under my devices one unit is connected. kindly post back with all this info so that i may help you further.
Regards
Oct 11, 2010 | Intel Desktop Board D815EEA2 Universal...
No power to Protron pltv-32tv changed power cord still no power
You need to check and find out if you do have standby +5vdc at the power supply connector, if you do and the the Red indicator on the front is not on, then you have the problem in the main logic board. Post back what you find.
You have to have this 5v or nothing else will be turn on. New or used power supply is installed?
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
May 23, 2010 | Protron PLTV3250 32 in. LCD Television
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Can't turn on computer
you may try:
1)open cover take out all exterior devices like cdrom/HD/PCI card/AGPcard then power on, go next if nothing change.
2)open cover see any fan turning when power on , if nothing run, check biger power supply plug pin(Ps-on and 5Vsb)all at 5V are OK, less than 3V or nothing is power supply box damage. change new power box to test. still same trouble go next
2)open cover you can see a LED light on on the motherboard
and check power on button is working well(switch).
3) check all biger capacitor top, any one bulged shows motherboard DC damage and need to repair by PC specialist.
4) nothing change above, you have to change motherboard.
Dec 21, 2008 | HP Computers & Internet
Gateway GM5472 PC Desktop Logo
136 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
