Question about HP Deskjet 460 InkJet Printer
After completing a print project the power light went out and now it will not turn on. I cannot see where there might be a fuse to check. Do you have any suggestions? Thanks, Jim
  • 30 Answers
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. 1) Press and quickly release the Power button (After completing a print project - c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power buAfter completing a print project - c01602202.gifc="http://i.fixya.net/uploads/images/c01602202.gif" alt="c01602202.gif" class="h_mi" /> ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
2) Unplug the power cord from the electrical outlet, or the power strip or surge suppressor.
  1. Carefully insAfter completing a print project - c01733891.gifr cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  2. Disconnect the power supply from the rear of the product.
  3. Wait at least 30 seconds, and then plug the disconnected power supplAfter completing a print project - c01733891.gifctrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  4. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  5. If the After completing a print project - c01602202.gif does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on
  6. If the product turns on , the electrical outlet in the original room caused the issue.
  • If the product still does not turn on ,After completing a print project - c01602202.gifh the next solution.
3) Disconnect the USB cable from the rear of the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. If the product turns on with the USB cable disconnected , replace the USB cable
  3. If the product still does not turn on , continue to the next solution.
4) If your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery
5) If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product
6) If you have completed all the preceding steps and are still experiencing a problem, service the product
Posted on Mar 26, 2011
Lightning struck my house and my tv went out I think it blew something in it like the circuit board are ther more than one board in these tv
If the power light doesn't come on then first look for a fuse. It's very likely a fuse. If all fuses are good and power comes on you might have lost a circuit board. Check eBay for boards. Part numbers are printed on them. They just unscrew and unplug. However it could be either board.
Dec 11, 2014 | Mitsubishi WD-73C9 73" DLP TV
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA P52810lv will not power on
Completely dead with nothing suggests maybe a blown or open fuse--first step would be to unplug and look for a fuse--follow the power cord.
Jun 11, 2012 | RCA Televison & Video
61uwx10ba. no power to any boards but power supply.
have you reched around the new soldering area carefully, check for solder spills or drops in the printed circuit, also another thing to look for is some of those replacement stk do not hold their weight, you might want to take them out and try the old ones to see if you recover tv power.
Jan 15, 2010 | Hitachi 61UWX10B 61" Rear Projection...
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 42in. Projection TV will not turn on.
check the fuse on the Main filter board ( The board where the power cord attaches to) as that fuse can often be blown and that will cause the set to be completely dead.
Apr 12, 2009 | RCA Scenium D40W20 40" Rear Projection...
Will not power on
The power supply has detected a problem, most likely a blown fuse caused by a bad convergence IC. If this is the problem the parts cost is around $50, but printed circuit board work is required to fix it.
Jul 06, 2008 | Mitsubishi WS-65807 65" Rear Projection...
TV won't turn on - no power
Thats the V23+ chassis. There are numerous fuses to check. There are 9 regular fuses they are F9A01,F9A02, F9A03, F9A04, F9A05, F9A06, F9a07 &F9A08. Also there is another Fuse F5A00, F9D00 and there are 2 ceramic chip fuses numbers F9B00 and F9B02. Let me know if you need further info.
Feb 28, 2008 | Mitsubishi WS-55613 55" Rear Projection...
SAMSUNG PCJ522R 52IN Rear Projection TELEVISION WILL NOT P OWER ON
1)Check PC boards for CRT coolant leak.Look closely at the
signal board and the main/power PCB.
2)Check any/all fuse devices in power supply
3)Let me know your findings....T.
Oct 23, 2007 | Samsung HCN4727W 47" Rear Projection...
No sound or picture
Keith, Check fuses Then Resoder The COMPLETE board I bet there is heat related problem W/Old Soder Just a Hunch!!!!!!!! G'Luck Chance One 559 @ Yahoo . Com
Oct 24, 2006 | Toshiba TP55G60 55" Rear Projection...
HP Deskjet 460 InkJet Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
