Question about Mtd Garden
I have a White model LT-1650 and was mowing when the engine stopped. I could not restart it even after waiting for a couple of days. The battery is good, the tank had gas.
wadembly
  • 513 Answers
SOURCE: Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
GM Elec
  • 1000 Answers
SOURCE: mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Posted on Jul 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: gas flow stopped mid mow, tank to carb has good
The ignition circuit starts and ends with the battery. When the engine is running the battery is continuously being recharged by an alternator or, on older systems, a generator. Current flows from the positive terminal of the battery to the ignition switch and an ignition coil. The ignition coil is really a transformer that steps up the 12-volt current of the battery to somewhere in the neighborhood of 25,000 volts. In engines of medium to high compression this kind of voltage is necessary to reliably arc across the gap on a spark plug and make enough fire to ignite the fuel/air mixture in a cylinder.
MORE HERE
Posted on Jul 19, 2009
  • 61 Answers
SOURCE: engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Posted on Sep 06, 2009
agent91
  • 2100 Answers
SOURCE: see below
A couple things, is it full of grass and hay up top that would cause it to overheat? Or the fuel filter got clogged up from debris in the tank. Or the governor spring came off, loose, make sure it moves freely, and then check the air filter. Then before filling the tank up, peek in there with a flash lite and see if there is any water floating in the bottom. Then check the spark plug. Hope one of these helps.
Posted on Jun 22, 2010
Need wiring diagram for white outdoor riding mower lt 1650 --tractor 425d hydro
Try Googling (white)(1650)(manual) without parens.
Jun 26, 2017 | Garden
Husqvarna problems
There are so many reasons for this it could take all day! First check the safety cut-out switches: seat, brake, drive lever and blade control, etc. Then check the battery leads and connections are clean and tight at the battery, starter solenoid and starter. If still no luck make sure the engine will actually turn over by removing the spark plug(s) and turning the drive pulley. Good luck!
Jul 15, 2014 | Husqvarna Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Craftsman LT 1000 Model: 917.272650 I put a new battery in over the weekend and was running perfect for most of the day Saturday. I got off it to empty the bagger, and as normal, the engine stopped. I...
check to make sure that mower deck drive is not engaged. there is a switch that the lever presses on it must be free. also check for seat switch cables loose or disconnected. Also make sure it is in neutral and not reverse as it may also kill the circuit for safety. Depends on you system for mow backwards. with key on you can short the two large terminals on solenoid to see if starter works. if so you must check all safety switches . try setting park brake before trying to start too.
May 17, 2013 | Garden
ENGINE WILL NOT TURN OVER, EVEN WITH A FULL BATTERY CHARGE AND JUMPER CABLES. THE STATER ENGAGES AND THE FLYWHELL TURNS ABOUT 1/4 REV. AND STOPS. IF I MANUALLY ROTATE THE ENGINE MORE THAN 1/4 TURN (PAST...
I am betting you will not believe this, but, your battery is bad. I just had the same problem last month. Same, same. I have always had good luck with jumper cables, but there was something wrong with the mower battery. When I removed it and replaced with new one, everything is as new.
May 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine stopped while mowing...tried to restart...nothing.
I am having the same problem. The PTO in engaged and won't relase. The engine won't turn with PTO engaged, you need to disengage the blades to restart.
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Craftsmen LT 3000 will not crank
That Briggs engine is not a good engine it has a weak governor gear that is known to come apart for no reason what so ever it may have done so and some of the parts stopped the cam gear from turning. Good luck!
Aug 24, 2009 | Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
219 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
