Question about Pegasus Technologies Pegasus 883-0004 Veronique R/T Handshower - PE8830004 - Brushed Nickel
Shower leak on Pegasus 873-0004. I shut off screw on hot and cold water on the side and still leaks. I need to koe how to remove PR20006 to change the rubber gaskets. thnak you
4 Suggested Answers
meBNme
  • 334 Answers
SOURCE: I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Posted on Jan 13, 2009
diodeic
  • 1622 Answers
SOURCE: I have 2 Pegasus showers,
Hi, you can remove it.Try and remove, just remove it gently that all will not get damaged..
dirt always contribute to the stoppage of flow of water.. So will need to Open and clean up to see if there is no obstruction blocking the flow of water inside of it...
Also there is a wheel inside closing and opens when the flow of water wants to come out..After clean up and still does not fix the problem, means the wheel is bad and the shower handle will need to be replaced.
Good luck..
Posted on Apr 18, 2011
  • 343 Answers
SOURCE: No cold water to bath
I believe you are talking about the brass or cast body, if it is a metal part remove the plastic valves and heat it with a torch and it will free up.
If that fails Moen guarantees there product for life. If you contact Moen they should send you a replacement part. They sent me 4 for all my faucets when I had a problem. Her is the link to there support.
http://www.moen.com/consumer-support
Thanks for using FixYa
Posted on Jul 11, 2011
Have changed all washers and reseated taps in shower but shower head still leaks
hi mark.
this is all i could find on the internet,if this is no good to you go to the link at the bottom and see if it helps you out.
First, feel the water leaking from the tub spout or shower head. If it's warm, you know that the leak is coming from the hot-water valve. If the water has been dripping for a while and it is cold, the leak is probably coming from the cold-water valve. 1Start by removing the faucet handle.22 Nov 2016
How to Repair a Leaky Shower Faucet Valve - HomeTips
shower head leaks Google Search
Nov 18, 2017 | Home
I jhave in my showers the Moen and One handle tub and shower faucet, model # T3132. When I turn it on in the showers, there is no hot water... in both it gives me only cold water... even if I turn the...
As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced. On both sides of the valve are 2 smaller screws. these are the water shut off valves. turn off the water and remove the larger screw fitting. remove spool and replace. Hope this helps.
Dec 21, 2010 | Moen & One Handle Tub & Shower Faucet
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Jul 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Jan 13, 2009 | Union Pegasus F1228100PBV Series 5000...
Pegasus Technologies Pegasus 883-0004 Veronique R/T Handshower - PE8830004 - Brushed Nickel Logo
159 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
