I just recently changed the battery on my 99 passat and now i found that my car is idleing very roughly , they say if i keep riding it everything should reset itself , is that possible or do i have to take it to my mechanic
Try to unplug the negative side of batt and let it sit for 5 minutes- then reattach cable and see if computer reset itself. If you have the same problem it may be the gas- check fuel filter and make sure it didn't pick up trash- also make sure it's not something like water in your gas- did you fill tank up same day?
Posted on Mar 26, 2011
98 oldsmobile achieva 3.1, replaced head gaskets, now it idles rough
If you tightened the rockers too far, the valves are probably leaking.
Oct 31, 2017 | 1998 Oldsmobile Achieva
How difficult is it to change the ignition switch in a 99 VW passat? Dont want to get in over my head if im gonna have to pull my whole dash apart
There is a lot to changing a ignition switch. If your key is in the dash, you will have to take it off. If it is on the steering column, you have to take that out. There is just no easy way to do it. It is a lot of little things that you change. You can do it, don't get me wrong. It is just rough sometimes cause everything has to go in perfect. Your choice of course, just being honest.
Mar 03, 2011 | 1999 Volkswagen Passat
2004 Chevy Trailblazer idles rough. Idles ok when started up, but after warmed up it idles really rough when stopped.
If it has not pulled any codes (idiot light). Clean your throttle body, and change your spark plugs with A/C Delcos #41-103, most other brands will cause rough idle like Autolites and Bosch. This would be a cheap way to fix this problem.
If by chance you have just recently changed the battery or had the battery unhooked. Let me know, it's an easier fix that costs virtually nothing.
Nov 18, 2010 | 2004 Chevrolet TrailBlazer
My 2002 Trailblazer idles rough with the AC or defrost on when stopped. It rides fine while the car is moving. I changed my battery a couple of months ago and then the problem started. Thanks for your help
I would suggest having the Alternator checked for the proper amp output. Although it may be making enough power to keep the battery charged, it may not be making enough to power the vehicle and still be the reason the engine performs rough at low RPM's under accessory load.
Oct 29, 2010 | 2002 Chevrolet TrailBlazer
Diagnostic Codes p0171 bank 1, and p0174 bank 2 (too lean)
Those codes are for the oxygen sensors, lean fuel mixture on both banks. Change them, problem with stalling and rough idle should go away.
Apr 23, 2009 | Ford Expedition Cars & Trucks
99 Dodge Durango Dies When Slowing
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Feb 09, 2009 | 1999 Dodge Durango
99 VW Crapio
what tha generally means is your o2 sensor is throwing a fault code. this is mostliely due to the fact that your TPS (throttle postion sensor) is not functioning properly. this is why there is also a rough idle to the vehicle. have the TPS replaced and the problem will be solved.
Nov 09, 2008 | 1999 Volkswagen Cabrio
Rough idle
fuel filters rarley cause idle problems. i would look at the egr valve or possible vaccume leaks.
Aug 24, 2008 | 1999 Buick LeSabre
52 people viewed this question
 Grubhead
Grubhead
