Question about Dual XDVD8181 Car Video Player
No subject whats going on man, i have a 2002 monte carlo and i had a good sound from my speakers from my factory cd player. then i put in the dual xdvd710 and my sound wasnt near as loud as the factory cd player i had. what do u think is going on with that? thanks
    Problem Solver:
  • 4 Answers
Turn the loud (On)
Posted on Aug 07, 2008
SOURCE:
The CD player in my factory stereo has a CD stuck inside of it. We know that the radio is programmed for this VIN # only. Can I unplug the stereo and fix the CD player and then plug it back in without...
Try disconnecting the battery for a few seconds and try to eject the cd, if this don't work you can take the cd player to the dealer ship and they can send it to be repaired
Aug 05, 2011 | 2004 Chevrolet Monte Carlo
My 2002 monte carlo ss sunroof won't go all tha
Sounds like it is going off track whenever it gets to the popping sound point. Or its catching against something, Check to see if anything could be in the tracks of the sunroof. Hope this helps, James Booth. Let me know what happens
May 17, 2011 | 2002 Chevrolet Monte Carlo
How hard would it be to put a different cd player in my 2003 Monte Carlo SS ??
It is very simple actually. What you will need is a face plate, an aftermarket wire harness and the skills to connect this wire harness to the new CD player harness, they are usually color coded so very simple. TO remove you stock CD player you will need to pry off the plastic surround then there are 4, 7mm bolts that will need to be taken out and the stock CD player will pull out. Unclip the wire harness and antenna
Apr 01, 2010 | 2003 Chevrolet Monte Carlo
Hook up aftermarket cd player but factory amp wont turn on in 2000 monte carlo. get bass from subs just nothing on inside speakers
Make sure you purchased the correct audio kit for your car year and model. If you did, check with custom audio stores and check their kit, usually theirs always work, but will cost you about $25. Expensive for just a plu.
Mar 13, 2010 | JVC KD-G310 CD Player
CHECK CD LIGHT ON RADIO WILL NOT GO OFF HOW DO I
cd player in 2000 monte carlos reads check cd what is problem
Oct 08, 2009 | 2000 Chevrolet Monte Carlo
Noise in speaker
sound like you have a grounding problem. something is lose or not ground out properly. change the radio/cd player and see what happens only if the old radio is still with the vehicle.
Jul 07, 2009 | 2001 Chevrolet Monte Carlo
Audio display says check cd
This may be a bit late to help, but I just had the same problem yesterday. Same car (2000 Monte Carlo SS), but mine is just the CD/radio stereo (no cassette). I was able to solve it by pulling the fuse for the radio (it's in the right-side panel) and letting it sit for a minute. After putting it back in, the CD player made the disc ejecting sound one time (no "check CD" message) and stayed off. And now it seems to be working fine. We'll see how long it lasts, though.
Mar 25, 2009 | 2000 Chevrolet Monte Carlo
Factory cd player wont play burnt cds
A '96 CD player can't see newer burnt Cd's. Found that out with my '99 Chrysler.
Feb 26, 2009 | Phase Linear UDV9010 Car DVD Player
Radio and cd player stoped working suddenly
the security on the radio has been tripped you need to take it to a GM dealer and have them run a code to unlock it CAL means calibrate
Jul 04, 2008 | 2001 Chevrolet Monte Carlo
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Dual XDVD8181 Car Video Player Logo
89 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
