Question about Calibre Radar Detector
My front detector has stoped working, and needs to be reset. How do I do this?
As per request. re: reset/fix indoor motion detector.
on all the Honeywell or Ademco wireless motion detectors I have worked on the light will not come on with the cover in place, it is set that way to conserve battery life. If you want to be sure it is working properly arm your system and wait at least 4 minutes before walking in front of he motion then walk in front of it and see if it trips the alarm.
May 05, 2014 | Honeywell Ademco Apx32en Alarm System...
SOUND ON Whistler 1585 Radar Detector STOPED Working
You can order a replacement speaker and install it yourself by calling 800-531-0004 The speaker costs $10 which includes shipping. Tip, when removing old speaker make certain to note how the speaker wires are routed this is important.
Nov 10, 2011 | 1585 Radar Detector
Speaker stoped working, I need a replacement speaker. Where can I find two speakers?
Please call 800-531-0004 this is Whistler's toll free number and you can order a speaker from them.
Sep 22, 2010 | DE-1793 Radar Detector
Reset to factory settings
have you tried the companies website? Beltronics lists models going back 4/5 yrs!
Apr 20, 2008 | Express 795 Radar Detector
Radar Detector in not working in New 350Z
It appears a different outlet-power port does not set off the radar detector. I do not know the reason for the difference but it appaears to be ok at the 2nd port. I will monitor the situation for a while
Mar 21, 2008 | Vehicle Parts & Accessories
Whistler 3300
Did you look at Whistler's website for R1 error trouble shooting steps?
Nov 30, 2007 | 3300 Radar Detector
Vs-50605 Mitsubishi
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
May 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Calibre Radar Detector Logo
136 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
