Question about Supersonic SC-33DM Player
Player works good. but the remote will work for only a few minutes and then stops working. this the second remote i have tried, the player is new just a couple of days old . have already tried new batteries and still won't work . please help, my next option is to return the player back to the store.
  • Supersonic Master
  • 508 Answers
There could be a number of possible reasons for 'no remote control' operation/function with these units. One of those could include the remote itself; this device may have a fault where its battery current drain level is too high, resulting in batteries going flat very quickly. That would be a bad remote design, or the remote itself is just defective.
Another possible reason for remote failure, and probably the most likely, is a faulty IRD controller circuit (IRD - infra-red detector/remote sensor); this circuit is governed by several components including a controller IC, and the IRD is usually a small encased metal block with holes to allow the receiver to detect the pulses from the R/C. Either this and/or the IC fails completely or partially, resulting in no remote function. This circuit is in the main unit - sometimes manufacturers under-design these circuits or use poorly rated components, hence the multitude of faults.
It's nice to be able to operate the unit with a remote as well as front panel buttons. However, since it is still relatively new, and you have some warranty, send it back to the store - don't bother trying to get this one fixed - as there is a chance something else could go wrong with this later on. I recommend that you go back to the store you bought this from and insist on an exchange unit of a better brand/model which DOES work properly, including remote, don't accept their offer to send it off to get it repaired - you want a working one NOW.
Fingers crossed that you eventually get a working product which satisfies you completely.
Posted on Mar 28, 2011
I bought a second hand VD player with remote, player works great but remote does not work at all, even with new batteries
Buttons on the remote control should work individually. If it is universal remote control [not the original one with the projector], you should have to set it up with its set-up codes. For more details, you have to download the manual to the remote control you have, if it is a universal one. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 24, 2014 | Televison & Video
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
I can't seem to sync my wii controller. All 4 lites are blinking and will not stop. I changed the batteries and tried to re-sync the controller w/no luck. It was just working a few minutes ago.
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
Jul 12, 2011 | Nintendo Wii Remote Controller
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
My remote suddenly stopped working.
If you're seeing on the LCD of the DVD player something like "DVD1" every time you press a button on the remote, try this: Change the command mode of the remote to match the player. Do that by holding down the Enter key on the remote and pressing the respective number. In my example above, hold Enter and press button 1 to set the command mode of the remote to DVD1. I had this problem and even unplugging the player didn't help, but the above worked for me.
Jul 16, 2009 | Sony RDR-VXD655 Recorder
Cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
Dvd player stuck in 'demo repeat mode'
press and hold the power button for about 5 seconds to reset the player
Aug 13, 2007 | LG DN798
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Supersonic SC-33DM Player Logo
111 people viewed this question
Top Supersonic Televison & Video Experts
Demonic-2011
Demonic-2011
De ice
De ice
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
