Question about Ruud Heating & Cooling
I need the wiring schematic for RUUD gas furnace model # UGDE-14ERAJR. The serial #AG5D307F42890894. Thank You, David Czajkowski 732-469-4264
  • jageechi Mar 27, 2011
    If there was a schematic on the door I would not be asking you for one, I need the schematic to solve the problem. if you cant get it for me dont charge me your fee.
  • 8,220 Answers
Rich tips for hvac knowledge seekers
Whats going on with the unit. Can't nobody find schematics online for HVAC.
Posted on Mar 28, 2011
  • 43,501 Answers
Hi David,
That is a very obsolete furnace as far as furnaces go...
Finding a manual or schematic will be difficult...there should be one on the inside of the bottom door or on the side of the furnace on the inside...I can't remember exactly where...
I have worked or way too many of those and can probably tell you what you need to know if you can relay to me what it is doing or not doing...
Please comment back and let me know what is going on with your furnace...
Also check the insides of the furnace and the doors for that schematic...
heatman101
Posted on Mar 26, 2011
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
Need wiring schematics for goodman manufacture model # A60-20REV/C gas furnace
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
Jun 27, 2008 | Goodman Heating & Cooling
How old is a ruud furnace model number ugaa- 08KC, ser. number RN3D104F18794988
Hello, The model number for Ruud/Rheem equipment is located in the 12-13 digits, these appears to be a 1994. I have seen some furnaces with an age older than when the home was built (a 1995 furnace in a home built in 2000), so good job checking the serial number. This gives you the age it was manufactured.
Hope this helps James
Apr 03, 2011 | Heating & Cooling
Schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Sep 21, 2009 | Ruud UBHC Air Conditioner
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Jan 02, 2009 | Ruud UBHC Air Conditioner
RUUD ugde-12erajr 80Plus Ignites and gas is shut off after about 30 seconds.
LOOK FOR A NEEDLE LOOKING PROBE ON LEFT SIDE OF BURNER ASSEMBLY. BE SURE ITS CLEN . YOU CAN CLEAN WITH A LITTLE STEEL WOOL OR SAND CLOTH. BE SURE WIRES ARE SNUG TO CONTROL BOARD. BE SURE ALL LOW VOLTAGE CONNECTIONS ARE SNUG AND A GOOD GROUND. IF IT STILL SHUTS DOWN THE BOARD IS PROBABLY BAD. I THINK ROBERTSAHAW MAKES A GENERIC REPLACEMENT FOR THESE.
Oct 20, 2008 | Ruud Heating & Cooling
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
117 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
