Question about Maytag Washing Machines
My Maytag Performa 2300 appears to have grease leaking out of the point where the top of the agitator connects with the bottom of the agitator.
Get a new one. You either have a bad tranny or a seal leak. Either way the cost is about 60 - 80% of the cost of a new one.
Posted on Aug 04, 2008
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Could you please tell me how to remove the agitator for cleaning on a Maytag top loading performa machine heavy duty.super size 3 speeds quiet series 100 13 cycles Thank you Bob Clark
The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Seal leaking from tub. How do I remove agitator?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
Aug 11, 2008 | Maytag Washing Machines
Maytag Perfoma 2300
check to see if they have rubber washers in them
Jan 28, 2008 | Maytag Performa PAV2200
Maytag Performa Large Capacity Top-load Washer
the agitator should have a SCREW, AGITATOR RETENTION that holds it on ..see brakedown. unless you are talking about the DISPENSER, FABRIC it should just snap on. let me know if his helps krazytech
Sep 09, 2007 | Maytag Performa PAV2200
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Open Questions:
Washing Machines Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
