Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
My linksys e1000 router works wirelessly with all my computers except my laptop which uses windows vista SP2, my network card is atheros ar5007, and my ISP is COX. I understand that the network driver is not compatible with the E 1000 router
  • oschik Mar 26, 2011
    Hi Sam, HP dv7 notebook. I am pretty sure it's the driver as it sees other wireless networks but next to my wireless network there is a big X that says my computer is not compatible or something to that effect. I talked to a linksys rep and he told me that the issue is with the network driver. I don't know how to change the network driver but that seems to be the only solution.
    Problem Solver:
  • 5 Answers
Most of the times you would be right when you say its a driver issue. :)
But there are certainly few steps that you can try as in -
a) Making an other third party program manage wireless on your XP SP2 machine
b) Tweaking the wireless channels to check if there is interference(this must have minimal impact as you already state that its working with everything else).
Try downloading a third part freeware to manage your wireless connections and uninstall the arheros client.
But before doing this try with windows client as well.
What is make and manufacturer of the XPSP2 machine??
Sam
Posted on Mar 26, 2011
Forgot the wiFi password
CISCO/Linksys -To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 27, 2013 | Cisco Linksys E1000 WirelessN Broadband...
Can't connect to internet wirelessly
'is a wireless card and a wireless network card the same thing?'
answer:- yes they mean the same device, just a different way of referring to it.
'Is this both hardware AND software?'
answer:- no, it's just the hardware.
Also, have you typed in the security code from the router (the WEP key) if not sure, google 'wep key'
Don't spend $, hp are excellent with their update site.
Are your other computers using Vista and working wirelessly ok?
Do you get any signal quality indicator bars up on the Atheros window?
Have you tried 'rescanning for networks' ?
How close to the router are you? If not very, try positioning laptop adjacent to it and do a rescan.
Jan 03, 2013 | HP Computers & Internet
Windows 7 Atheros network adapter will not connect to WRT54GS Linksys Router
First, use a lan calble to reach the router. Then check the settings on the router and see what ip address is assigned to your laptop. Also check the password setting on the router. Try using WPS as an alternative to setting up the password, etc. WPS will work with either a pin number or push button. It should solve your problem. If not, then use the first solution, although it may be a little more complicated for you. Last thing you can do is go to into Microsoft's network and sharing center, and choose "manage wireless networks" and make sure the adapter is "enabled".
Jun 23, 2017 | Cisco Linksys WRT54GS2 Wireless-G...
Linksys E1000 Wireless Router limited or no connectivity
What is the operating system on your computer?
Are you trying to connect to the wireless network?
on Windows XP computer you will get this message when the computer is not able to connect to the wireless network.
There are 2 reasons. You might have entered incorrect password or your computer is not getting IP address.
Read Limited or no connectivity
Oct 03, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
Just purchased a Cisco Linksys E1000 Wireless-N Router. I am unable on my wireless laptop to connect to the internet. The Error I am getting from my computer is: The settings saved on this computer for the...
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Enable Atheros AR5007 WiFi with UBUNTU 8.1 64 bit
you dont need to install drivers in vista . just search for new automatic updates all drivers will install automaticaly
Mar 10, 2009 | Computers & Internet
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
312 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
