Question about Bosch WFVC4400UC Washer
WFB 2500 motor not turning during wash and spin everything else seems to work. have changed out motor and control board , no change ???
SOURCE: Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Posted on Jul 16, 2007
  • 62 Answers
SOURCE: Bosch Model WFB 1605 washing Machine
Try online...you'll need the full model from the machine. Try general search or go to bosch's web
Posted on Jan 03, 2008
SOURCE: Bosch WFB 1605 washing machine
please give us an instraction on how to yoe the Bosch WFB 1605 washing machine
Posted on Apr 04, 2008
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Washing Machine model WFG2460 drum doesn't turn
There is no start capacitor on this washer if it has brushes in the motor, most likely the prob is due to worn brushes, to check them, do the following.
Remove rear panel, remove belt, remove motor plug.
Undo 2 screws securing motor, lever motor back with a screw driver or similar, keeping hold of motor and remove motor,.
You will find the brushes at the opp end to the motor pulley, replace if less than 1cm in length.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
3E error during rinse cycle on Amana NFW7200TW washer
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Oct 18, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My kenmore washer will not spin model number 41744082400 everything else works should i change control board
No that will not solve your problem. The ctrl board isn't reading movement from the motor. Replace the motor only. maytagplb@yahoo.com
Sep 15, 2010 | Kenmore Washing Machines
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
No spin cycle
Before you try changing the control board, try changing the brushes of your motor.
Jun 14, 2008 | Washing Machines
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
Washer wont spin
Is the lock door light on if not change the wax motor & the main control board (board is approx $169.00+).That is the problem unless the belt slipped off .Common neptune issue you have will most likely repeat itself so,you decide from there.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bosch WFVC4400UC Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
