Question about Eaton ARC FAULT CIRC BREAKER
I have 3 bedrooms, each have their own arcfault breakers. i plug in a sawzall and one bedroom trips, fast at the end of the circut an takes longer at the begining. i have chect for shorts, removed and isolated all wires, it happens just some of the time. i also swapped breakers having the same result. the other 2 bedrooms work fine. does their have to be fault in the line some where to trip under load. if no load does not trip
    Novelist:
  • 157 Answers
Hello. The issue could be with the saw itself. If the breakers are 15A (and for bedrooms, they should be) and the tool draws that or better, then the breaker will trip. The reason it trips faster at the EOL (end of line) is due to the resistance in the wiring itself. The further away from the initial source - the more loss/resistance.
Truthfully, the arcfault function is designed to detect arcing in a circuit. AFCIs disable the circuit immediately if they detect any type of problem (read "arcing") in the circuit. since the sawsall motor functions DUE to acring of the brushes on the motor, your circut is actually behaving according to design.
The final issue could be that the tool IS causing an issue, and may need repair.
Hope this helps.
Posted on Mar 29, 2011
I have three upstairs bedrooms that are all on the same circuit. My sister tried to plug in something to an outlet in her bedroom and it seems that she jiggled the plug into the outlet and the power went...
I know this may have already been checked, but make sure that any gfci may have not tripped, and also, reset all the breakers if the gfci thing doesn't work... Trust me i know it is annoying but resetting all of the breakers almost always fixes the problem.
Aug 02, 2011 | Electrical Supplies
I have bedrooms with arc fault breakers in them. Randomly, the breaker will trip for no apparent reason. Usually only the lights are on in the bedroom, and nothing is plugged in to the outlets. The room...
If your arc fault breakers are tripping, then there is an arc developing somewhere along the line from the panelboard to the rooms that the breakers cover. If they are breaking in more than one room, then the fault lies in the lines somewhere between the panel and junction to these rooms.
You would have to trace the line from the panel to each light/outlet until you find the problem. Remember the arcing could be occurring anywhere, in the line, at the light, or at the outlet.
Your brother should be able to check each section of wire for continuity rather than ripping out all the wires in those circuits.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 27, 2011 | Siemens Seimens Arc Fault Breaker
Air conditioners switched off last night only the kitchen one is working and one bedroom, we have 7 bedrooms 3 receptions, control panels are manufactured by General Electric and the display is blank. For...
If it is more than 1 AC, It is most likely an electrical problem, check the circuit breaker panel for tripped breakers, Check if the AC is plugged in to the wall, That a small button on the receptacle is not tripped this could be in any room on any receptacle, 2 small buttons, one says test and the other says reset.
May 10, 2011 | General Heating & Cooling
My husband has recently moved & is using several electronics into our spare bedroom & he keeps flipping the breaker! We have a sylvania breakers What do I need to do to fix this problem
Circuit breakers trip when then get hot.
They get hot when the line draws too many amps.
If breaker does not trip, then line overheats and causes a fire.
So tripping breaker warns that too many watts are being used.
Best solution is to run additional circuit into bedroom.
Another solution is to run extension cord from another room and plug one big item onto that cord.
I had same problem in a house we rented.
I pulled back carpet in corner and drilled a hole into basement, and then brought extension cord up from below. When we moved, the carpet went back down.
If you are qualified to work on circuit breakers inside the main box, you can move wire to another same-size circuit breaker to see if breaker is faulty. Do NOT put that wire on a larger amp breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuithttp://waterheas or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | Sylvania Electrical Supplies
I have two Siemens arc fault breakers that after a year have now started to trip whenever I plug something in. I can plug in a light, a TV, a modem, an iron and they trip immediately My bedrooms have...
Do you have anything plugged in? If they keep tripping with nothing plugged in I would call a electrician to troubleshoot or replace the breakers. They may still be under warranty from Siemans.
Feb 14, 2011 | Gen Tran Gen-Tran Siemens arc fault...
Arc fault breaker in Bedroom,trips when I plug in my computer laser printer,the printer works ok in any other outlet in the house except the master bedroom that is protected by a arc fault breaker.
My experience with these breakers is that there could be some minor short in the equipment that cause them to disconnect. I have a filter motor that will not run on my ground fault breaker if it gets wet. There may be no problem with the breaker.
Gary
Jan 07, 2011 | General Electric G.E. Arc Fault Breaker
I have a circuit breaker that is intermittent
It is unlikely that those temperatures would cause the circuit breaker to shut off and come back on intermittently. (If the breaker trips it has to be reset manually.) It is possible that the breaker is defective internally or that there is a loose connection in the wiring. If you are not knowledgeable about electrical work you should have an electrician check it out for you.
Nov 25, 2009 | Electrical Supplies
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
Eaton ARC FAULT CIRC BREAKER Logo
283 people viewed this question
Top Eaton Electrical Supplies Experts
john h
Steve
Are you an Eaton Electrical Supply Expert? Answer questions, earn points and help others
