Computers & Internet Logo
Posted on Mar 26, 2011
Zonet zfs3016 switch for second internet signal. I have cabins with 1 connection for office and1 for cabins. connection for cabins gone and no lights on zonet except where router is pluged in
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Jan 26, 2008
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Anonymous
  • 3 Answers
  • Posted on Jan 01, 2009
SOURCE: I have lost the disc to my Zonet Wireless internet router
Consider visitin the manufacture website if u have access to internet.if not.
Contact any hardware Vendor nearest to you they may have the router and help u
burn the drivers into an emty CD
Anonymous
  • Posted on Jan 21, 2009
SOURCE: no internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Anonymous
  • 33 Answers
  • Posted on Jan 25, 2009
SOURCE: my linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
BlackHand-En
Neville Vyland
  • 68 Answers
  • Posted on Jan 28, 2009
SOURCE: I want to put a password to my wireless network
you will have to use one of the encryption supported by wifi..
try enabling WEP on your wifi router....
How do I get my Zonet Router to play nice with my Motorola Modem and Comcast Connection?
If this types of issues again again then may be some technical Fault.
A> Your Network connectivity Not Good or loose.
B> Your IP Add or mac Add change or conflict.
C> Your Modem or router not proper connectivity establish.
D> Contact network ISP provider or ask some issues.
E> If possible check it loose connectivity and connection.
If not solved contact Network Support Technician.
http://setuprouter.com/router/zonet/zsr4154we/manual-915.pdf
Linksys Support Phone Number
Thanks,
1helpful
I installed a new Zonet 1605 wireless adapter so i could pick up the wireless internet from my niegbor it does not work why?
You are not able to pick up your neighbor's network can be due to various reasons.
1) Check if the adapter has been installed properly. Check the device status in the device manager. It should say "This device is working properly"
2) The distance might be too much for you to receive the wireless signals.
3) Might be having any other wireless devices like a cordless phone near your computer which may cause interference.
4) Your neighbor's wireless router might be transmitting signals in 802.11a or 802.11n standards which is not compatible with Zonet 1605 adapter.
5) Your neighbor would have password protected his wireless network to avoid illegal use of his internet. These days there is more importance given for wireless security.
Thanks and regards,
Arvind S Iyer
Not getting ethernet connection from the router to the modem
Please check your router's power is working or not.
if your router's power adaptor is OK the possibilty is your router's motherboard is faulty.
need to go service center.
Router says limited connectivity
Not a lot of info to go on, but I'll give you my thoughts on it. In my experience, limited connectivity indicates the modem isn't connecting up to the internet. You can reset the modem by unpowering it for a few seconds, then seeing if it will connect, but I'm sure you've already tried that. Could be a faulty modem, but I doubt it. Chances are there's a software incompatibility issue between the modem and the wireless card. Was the zonet working with the card before? If it was, you might have to go into Network in control panel and delete the linksys connection, and have windows redetect the Zonet. Sorry, all I can think of, not a whole lot of experience in this arena, and my routers always worked. Maybe someone will have had the same problem and know the solution, that would be the easiest way to go, of course.
I have a new laptop with wireless at home. How do I set up the wireless connection from my zonet router? Victor
By default, wireless routers always broadcast wifi signal. The only thing you need to do is to enable the wifi radio receiver of your laptop. To do it, make sure that you have the wifi LED lit in your laptop which means that your wifi receiver is ON. Now, you need to connect your modem to your router so that your router will then broadcast internet signal. Then you are good to go. Your laptop should get connected automatically and receive internet signal.
If you want to configure your router, visit http://192.168.1.1 when you are connected to the network so that you can change some of your router's behavior.
Wont get a signal or my wireless wont recongnize the zonet router 1104we cant get anything from it at all..thanks for helping me if u can
1. Try a power cycle / reset of the router, if it is not transmitting signals 2. If your computer is not getting signals at all, ( not even your neighbor's ) , try uninstalling the wireless card and installing it again 3. Make sure you the wireless switch in your computer turned on
Thanks Ranjit
1helpful
Zonet zsr1134we router abruptly stopped working
make sure your modem and your router are not using the same ip address. Many items default to 192.168.1.1. A reset of either device could return it to use this ip address.
No Internet is exactly what you get if your modem is 192.168.1.1 and your router is 192.168.1.1. The problem can happen if either device give out an ip address already used on the network. Change which ever one you can most easily find the documentation on.
I don't recommend using static ip addresses internally, unless your documentation requires it for your setup. changing the set of ip addresses that are distributed by DHCP is the best was around this problem.
2answers
Top Zonet Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
