Question about Garden
I'm lookin for a blade spindle assembly for model number 13AH660F372
  • 252 Answers
Hi pauly 46
here is web site
http://www.partstree.com/parts/?lc=mtd&mn=13AH660F372+%281998%29
its a good site as is the site www.ereplacementparts.com
here is the part you need from partstree.com
MTD 918-0138A (replaces 618-0138)
Blade Spindle ***'y. Comp.
you can order from this web site just find your model as above then the part
select it , add it to your cart and check out and pay
cheers pauly46
Posted on Mar 27, 2011
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
How do i replace blade on kobalt 12dual bevil miter saw?
I don't know the model of saw you have but they are made for fairly rapid and uncomplicated blade changes as users will change the blade fairly often as they cut different materials.
Some saws have a spindle lock which once engaged means the bolt retaining the blade can be loosened with a single wrench and some saws need the spindle holding with a second wrench which is usually fairly thin, in the order of 3 or 4mm, to engage on two narrow flats machined on the spindle.
The blade changing process is a fairly intuitive one and if you take the time to turn the saw over and observe how it is assembled I think you will soon get the idea.
Feb 03, 2015 | Saws
Remove mower spindle star is stripped blade moves
If star is actually stripped, you will have to replace the whole spindle assembly and blade. I would not change just the shaft if I was you as its almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade will not tighten star stripped on spindle
You will have to change the spindle and blade. I would replace the whole spindle assembly as just the shaft is almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Jun 02, 2012 | Mtd Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
I need to replace a deck pulley spindle assembly for blade
if you have a owners manual it will tell you but if not go to your computer punchin make model and a choice of sites will come up also sears parts direct will help u on the phone or enter your modle make and a parts list will come up good luck hope this helps.
May 19, 2017 | Mtd Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
