Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
I have a model SD-582HD5 58" TV Year 2000. It all of a sudden pops off to standby for no reason. Then it wont turn back on for awhile. What can we do to fix this?
    Problem Solver:
  • 6 Answers
It has a loose connection on one of the boards. To test this the next time it turns off, Power it down and then back up, While its trying to come on hit the side or kick the bottom and see if it comes on. Sometimes you have to hit it hard. If it comes back on its a loose connection. A tech will have to check all the connections and if no loose connections are found he will have to resolder the joints on the boards.
Posted on May 18, 2011
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Philips multi problems
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_27_2012_2_16_28_pm.jpg5_27_2012_2_16_48_pm.jpg
May 26, 2012 | Philips 52PFL5704D 52 in. HDTV
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
No Power
Take ur tv aparts.Ur tv power supply board,that the board where the power a/c cord plug into it.That is ur power supply board.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv shuts off go on standby wont power back up
make sure it is pluggen in all the way to the source of video or may need new cord
Nov 24, 2009 | Pioneer SD-P55A5K 55" Rear Projection...
NEW TV WONT TURN BACK ON
polorid known for going out take it back asap those have worse revies back panel go out ok no good please upgrade yourself to a nice samsung or sharp ok for best quilty for yrs to come u be happpy u did
Jan 29, 2008 | Televison & Video
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
