I have an Arris TM722 modem. The videogame Call of Duty: Black Ops has a built-in bandwidth test to determine who gets host more often. Wit my Xbox 360 plugged in through my router (I've tried a D-Link & a LinkSys) the bandwidth test says only 2000kbps a second or a 2 meg line! When I plug the 360 straight into the modem, it registers correctly for the 30 megabit line I have! I am not getting host because the 2000kbps is what it thinks I have. I cannot for the life of me pinpoint the issue. Through the router, regular internet speed tests (such as or on the computer show up normal, but the Black Ops speed test is giving me such a low rating. When I plug my Xbox 360 straight in, it's correct. How could two different routers be affecting the rating so much? The routers are both properly configured with Xbox Live ports open, etc. One is a $150 D-Link gaming router even! There are no features turned on in the routers that would cause a bottleneck of sorts? I used to have a different modem (Thomson) and the test ran just fine through the router for Black Ops. Why would the Arris modem be any different? I do not understand how adding a router into the mix between the Arris and my 360 is making it say I only have 2 megabits down. I plug straight in and it says I have 30. There is nothing else running on the routers either at the time of the test... (by having two routers, I mean I've tried two different ones)
  • 98 Answers
SOURCE: cant hook up xbox 360 to internet
does this help it sounds like you are puting your cable in to the 360 and the modem you wont have a internet ligth on untill you try to connect the 360 to go live you must reset the modem
Posted on Jan 25, 2009
  • 1879 Answers
SOURCE: ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Posted on Jan 26, 2009
  • 31 Answers
SOURCE: Linksys router and modem problems
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Posted on Apr 09, 2009
  • 68 Answers
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Posted on Jun 08, 2009
  • 1305 Answers
SOURCE: Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Posted on Sep 20, 2009
Testimonial: "Thank you for the advice! I did check and all the cabling is CAT5, so I just don't understand why there's a problem..."
On black ops for xbox, when ever i look up, i look down
Pause the game, go to control options, and either turn on or off Look Inverse.
Aug 29, 2011 | Activision Call of Duty Black Ops for Xbox...
Why will it not let me play on any game types or at all online. it keeps saying lost connection to or must be signed into xbox live acount.
you need an xbox live account, a connected modem to your xbox, and to sign in in order to play online games.
Apr 27, 2011 | Activision Call of Duty: Black Ops
I cannot get through more than 1 or 2 games maximum when playing on multiplayer Call of Duty: Black Ops for XBOX 360. It keeps crashing. This does not happen on single player, or nazi zombies. I can even...
It sounds like your internet provider/router isn't giving you a whole lot of bandwidth to work with. That simply means your internet isn't giving you enough space to actually play call of duty. Your zombie game is probably playing alright because only four people need to connect to each other. That doesn't require a lot of space and memory of internet to do. However multiplayer demands a lot more bandwidth from your router. That might be why you aren't connecting. This could be for a number of reasons.
  • Other people in your household are using the internet too, be it laptops, smart phones, printers, other gaming counsels, etc. Simply turn off these devices to receive more bandwidth for your xbox.
  • Your router is a little too older for video games. If you are using a wireless router for your xbox, try plugging it directly to the wall or router.
Hope this helps
Apr 06, 2011 | Activision Call of Duty: Black Ops
We recently got an Arris TM722 modem and a netgear wireless-N 150 router WNR 1000 after getting a new ISP. My problem is that every time I turn on my xbox to connect to xbox live, my xbox doesn't connect...
Recheck your settings on the xbox.
If using wifi on the xbox, you'll have to setup a new connection to the new router.
If the xbox is wired via cable to the router, you may need to add a router password or other settings .
Jun 21, 2017 | Computers & Internet
Playing Xbox Call of Duty Black Ops. On the defector level and screen goes black halfway through. Can see direction arrows and hear whats going on but nothing else. Is there a fix?
you have a faulty disk. i would take it back to the store you bought it from and exchange it for a new one. remember to bring you're receipt
Nov 16, 2010 | Activision Call of Duty: Black Ops
Online but its always waiting for 5 more players. Never enters into a game. Waited 30 min. or longer several times since Tuesday.
have you played the multiplayer before? i have had the same problem with black ops and also with mw2 and the only way i coulld play was by getting a friend to join a game then joining his session in progress. or by going through my recent players list and finding someone that was playing and join them. i think it has something to do with your internet or modem because if i take my xbox to my friends house it works no problems. hope this helps
Nov 12, 2010 | Activision Call of Duty Black Ops for Xbox...
How do I get the arris tm722 modem to go wireless?
Hi there!
Please check out this LINK
hope it helps
regards, fossildude
Oct 15, 2010 | Computers & Internet
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
342 people viewed this question
David Payne
David Payne
