Question about Gigabyte GA-M51GM-S2G Motherboard
Picture went saw toothed and when rebooting computer would not start
    Guru:
  • 433 Answers
Try another monitor if ok plug a vedio card
Posted on Mar 26, 2011
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
Best way to sharpen ms 250 c stihl chain
I can't show you pictures but I can try to explain. Tighten the chain on the saw to the normal working tension. If possible put your saw in a vice with the vice jaws clamped on the bar in a way that allows free movement of the chain around the bar when the chain brake is off. work your way around the chain to find the shortest tooth on the chain. Sharpen that tooth by using a file (4.8mm for the normal chain on that saw). You should work at 30 degrees across the face of the tooth.The spec says you should also angle the sharpening at 5 degrees from horizontal but if you have the chain at normal tension then the movement of the chain in the bar while sharpening is likely to give you about 5 degrees anyway - so just work horizontally and you won't have a problem. You only need gentle pressure pressing back towards the engine of the saw and enough strokes to get the surface of the tooth free of any pits, chips and rounded edges. When finished mark that tooth - I use a felt pen so it is easy to see. Do the same for every other tooth but to ensure the saw cuts straight (and does not give you curved cuts) it is essential that every tooth is sharpened to the same size as the shortest (use a measuring gauge if necessary). When you have been all the way round on all teeth then you need to adjust the depth gauges on the chain links. If you don't then the saw will probably only produce fine dust and not nice cut wood chips. With a flat file and depth gauge tool place the tool along the teeth pulled back against one. Through the gauge fingers you will see the chain depth limiter and this needs to be filed down to the level of the gauge tool. If you start the process at the tooth you marked earlier you will easily see when you have worked all the way around. Your chain should now be sharp. Before using it it is advisable to remove the chain from the saw and clean any filings out of the chain and bar to avoid them causing unnecessary wear. Good luck.
Sep 11, 2014 | Stihl Garden
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
REBOOT AND SELECT PROPER BOOT DEVICE OR INSERT BOOT MEDIA IN SELE
1, to open your cd drive manually, get a tooth pick, look closely onto your cd drive i mean where the cd comes out from when ejected, you will see a very tiny hole put the tooth pick inside the hole push it in a bit hard then bring out if it does not try a tinier object it will come out.
2, if the system was on when u disconnected the belt it might have burnt the hdd or has caused error on the hdd, off the computer and reboot if no solution, reformatt the system if it does not work, get a new hdd. thanks
Jul 16, 2009 | E-Machines eMachines Desktop PC
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
Transfer pictures
go to your pictures folder select the pictures then select copy or move and transfer them to your memory card.
Or you can install your smaung pc suite software and following the instructions
Aug 16, 2008 | Samsung SGH-E900 Cellular Phone
Vamw.zend failed.how can i fix it?
When i started rebooting centos and i saw the error logged vamw.zend failed. How can i fix it? thanks <--- ask www.zend.com and most probably you're not asking the proper question. garbage in, garbage out.
Feb 21, 2008 | Computers & Internet
Gigabyte GA-M51GM-S2G Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
