Question about Peg Perego John Deere Gator HPX
Peg Perego Gator accelerator not working in hi speed, only goes in lo
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Did you remove the high speed lockout?
Posted on Jun 08, 2012
momsjustknow
  • 149 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 156 Answers
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: Peg Perego Gator Ride On Toy
I had a peg perego gator hpx that was soing the same thing and I replaced both the high low switch and the reverse switch.
I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
hope this helps
Posted on May 02, 2009
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Posted on Jun 23, 2009
Peg perego gator only goes in low speed
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Jul 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
I have the Peg Perego Gator and when running it will stop. Happens more often in 2nd Gear. Sometimes when pedal it pressed it will make a motion forward and just stop. Could this be in the acceleration...
It might be the peg perego motor in the rear that is going bad, thus causing the fuse to trip. I had the same problem with my kids toy so I contacted a service center for Peg Perego at 1.801.655.0800
They were able to help me over the phone and get the right parts out to me.
hope this helps
Oct 11, 2010 | Peg Perego John Deere Gator HPX
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps.
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Only goes in 2nd gear
I would replace the high/low and reverse switch on this peg perego model.
I had the same problem so I got the parts from this site
May 08, 2009 | Peg Perego John Deere Gator HPX
Peg perego gator wont work in forward but works in reverse
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Peg Perego John Deere Gator HPX Logo
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
