Question about SanDisk Sansa Clip MP3 Player
How do I syncronize it? I have plugged it into the computer and his sync but nothing happen
  • 977 Answers
Hey!
To be able to sync it using Windows Media Player, make sure MTP mode is set as USB Mode within the device... Otherwise (in MSC mode), you can manually copy/paste the songs you'd like...
Regards,
Pelu.
Posted on Mar 28, 2011
Ignition timing for 96 dodge ram v8 5.9
Ignition timing on a 1996 Dodge Ram equipped with a 5.9L engine is controlled by the computer and is not adjustable. Attempts to adjust ignition timing by rotating the distributor will cause the fuel syncronization to be changed. If the distributor is moved or replaced, fuel syncronization should be checked and/or re-syncronized. This requires the use of a scan tool that can command the engine computer into "fuel sync" mode.
Apr 14, 2012 | Cars & Trucks
Dell Axim X51 and Vista
You need to download Microsoft exchange server to syncronize outlook on different computers.
Apr 18, 2008 | Dell Axim X51 Pocket PC
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
Caalendar on my desk top for my blackberry curve 8300
the blackberry will be using the Outlook calendar to update its information. its quite easy to use. What's happening is that the items calendared on the BB are syncing with the "private" calendar under the username (Outlook Today - Username - Calendar), and not the "public" calendar (All Public Folders - John Doe). No items are marked as "private" on the BB.
Install the Blackberry Desktop manager software and after its done go to the Syncronize Button. Once inside look to the left for configuration synchronization click this button it need you to be online to do this as well. inside it will list the many programs that can be used to sync your blackberry make sure you have already setup your outlook so that it can pick up the new settings your creating. once your all done look for the top upermost button on left of BDM ( blackberry desktop manager) and click syncronize to sync your blackberry. now once it is done your BB only needs to be plugged in and it will autosync itself. look in your outlook for new entrys and popup
Apr 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
Apple ipod 1gb locked and dont know the combination and cant sync
Connect it to the computer you normally sync with.
Open iTunes then disconnect the iPod.
If that doesn't work you can "hard reset" by restoring it to factory defaults. Doing this also erases everything you have on it so you will lose your movies, music, files, etc.
Connect it to the computer and open iTunes.
Click "Restore" and select "Restore" or "Restore and Update" to make sure you're on the latest firmware.
Good luck.
Feb 04, 2009 | Apple iPod nano
Wants me to "syncronize to continue music subscription"
I have the same problem, I have tried updating the clock using rhapsody, it should work for 30 days before needing to sync. ANY IDEAS anybody. I have requested help from SANDISK.
Jan 11, 2008 | SanDisk Sansa m250 MP3 Player
What is sync
the sync button is the syncronize button it lets you download music from your computer to your mp3.
Aug 02, 2006 | SanDisk Sansa m230 MP3 Player
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
Sep 12, 2005 | HP Jornada 548 Pocket PC
Zire 72 Won't Sync Notes
I feel your pain as I'm having even more problems than you, see my post. However, having learned quite a bit about this topic, I suggest ensuring the Hot Sync is set for the desktop to overwrite the PDA as opposed to PDA overwriting the desktop, which sounds like what's happening. That's the only suggestion I have. Hope it works out for you.
Sep 11, 2005 | Palm Zire 72 Handheld
Sync doesn't sync with Calendar, then Hot Sync crashes
Try Creating a New profile from Start Control Panle > Mails > show profile > Add profile > After Adding the profile set the new profile as default
Try deleting the partnership by disconnecting the device and opening and deleting the partnership.
Plug your device back and try to sync
This should work
Sep 11, 2005 | Palm Treo 650 Handheld
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
