Blower will not cut off - Heating & Cooling
    Genius:
  • 1,033 Answers
Hello, if the blower motor does not turn off with the thermostat than the relay on the integrated control board is stuck and should be replaced, the only problem is that the relay cannot be replaced by itself the whole control board must be replaced.
Posted on Mar 26, 2011
Pontiac G-6 blower on my heat will not turn off when I cut off engine. Light that displays internal temperature will not cut off either.
You may have two problems, the check engine light , you will need to have the computer scanned for codes . get me the codes and i can help you with that, you may need to go to a shop or an auto parts store that can scan codes.
As far as the blower staying on that may be a bad blower motor resistor , it may be back feeding power also. locate the resistor, the best way is to look under passenger side of dash.
locate the blower and then follow wires from the blower and to the side of it you will find the resistor it slides into heater box and plug sits out side box , the wires from blower will go to resistor, unplug resistor connector and see if blower cuts off. if it does then replace the resistor, here is a picture of it. good day.11_18_2012_6_22_48_pm.jpg
Nov 18, 2012 | 2007 Pontiac G6 GT Convertible
The heater blower stopped working and the fuse is not blown?
Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
To Remove:
  1. Remove the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  5. Disconnect the electrical connector from the blower motor.
  6. Remove the blower motor mounting bolts.
  7. Remove the blower motor insulating cover.
  8. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting bolts.
  3. Connect the electrical connector to the blower motor.
  4. Connect the cooling tube to the blower motor.
  5. Install the rear coolant recovery reservoir mounting stud.
  6. Install the coolant reservoir.
  7. Install the PCM.
W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
To Remove:
  1. Remove the PCM.
  4. Disconnect the electrical connector from the blower motor.
  5. Move the PCM connectors out of the way.
  6. Remove the blower motor access cover screws. CAUTION
    Do not cut any deeper than necessary in order to remove the access cover.
  7. Cut through the access cover on the cut line using a sharp utility knife.
  8. Disconnect the cooling tube from the blower motor.
  9. Remove the blower motor mounting bolts.
  10. Remove the blower motor.
To Install:
  3. Connect the cooling tube to the blower motor.
  4. Install the blower motor access cover.
  5. Install the blower motor access cover retaining screws.
  6. Using black weather-strip adhesive, seal the cut line.
  7. Connect the blower motor electrical connector.
  8. Reposition the PCM connectors.
  9. Install the rear coolant recovery reservoir mounting stud.
  10. Install the coolant reservoir.
  11. Install the PCM.
Feb 08, 2011 | 1996 Chevrolet Blazer
How to change blowermotor on 2001 gmc jimmy
To Remove:
  1. Remove the PCM.
To Install:
  7. Install the PCM.
To Remove:
  1. Remove the PCM.
To Install:
Dec 08, 2010 | 2001 GMC Jimmy
Where is the heater motor
You can get to it from the engine compartment, but you have to cut the cover off. There is an indented line showing where to cut. See picture below.
  1. For the 3.1L engine, remove the alternator belt, then remove the alternator and position aside.
  2. For the 2.5L and 3.3L engines, remove the power steering pressure hose from the power steering pump.
  3. For the 3.0L engine, remove the serpentine belt.
  4. For the 3.0L and 3.3L engines, remove the retaining bolts from the power steering pump bracket, then set the pump aside.
  5. Detach the blower electrical connector, then, if accessible, remove the cooling tube.
When cutting the blower motor cover, make the cut just the thickness of the cover, which is1/ 8 inch (2mm) thick. Cutting deeper than that may damage the cooling tube.
For 1992-98 vehicles, partially cut the blower motor case cover, as shown on the cover. Cutting completely around the cover is NOT required. Swing the cut potion of the cover down.
  1. If previously accessible, disconnect the cooling tube.
  2. Unfasten the attaching screws/bolts and remove the blower motor from the case.
  1. If necessary, remove the fan from the blower motor.
  2. The installation is the reverse of the removal procedure.
  3. If the case was cut during removal, secure the cover using the three retaining clips. Tighten the blower motor screws to 44 inch lbs. (5 Nm).
  4. Connect the negative battery cable, then start the engine and check the blower motor for proper operation.
Dec 01, 2010 | 1997 Pontiac Grand Am
Location of the blower motor
from autozone.com: access from engine compartment
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
  1. Disconnect negative battery cable.
Fig. 1: Exploded view of the blower motor assembly
973a989.gif Fig. 2: Some later model vehicles require you to cut the case, on the indicated lines, in order to access the blower motor
Fig. 3: On 3.0L engines, you must remove the power steering pump for access to the blower motor
Sep 22, 2010 | 1997 Pontiac Grand Am
Blower cuts off when compressor comes on. Blower
Try the fan"on/auto"function switch at the thermostat when the compressor is on.Set fan to on.Does blower run?
Mar 19, 2010 | Coleman Heating & Cooling
How do I remove the blower motor on a 2005 Chevy Silverado SS?
The motor is above the passengers feet.
Remove the screws then twist it and it will drop out.
Nov 01, 2009 | 2005 Chevrolet Silverado
How do you change a blower motor
FOR THE YUKON FAMILY THE BLOWER MOTER IS ON THE RIGHT SIDE OF THE CAB PULL BACK THE PLASTIC COVER OR CUT IT OFF REMOVE THE 3 OR 4 SCREWS THAT HOLD IT IN PLACE CUT THE WIRE TO IT AND THEN REMOVE IT THE NEW BLOWER WILL HAVE TO BE WIRE TO THE WIRE THAT YOU CUT AND THEN SCREW THE BOLTS BACK AND YOU ARE DONE .........
Oct 01, 2009 | 1995 GMC Yukon
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
