Question about Sharp DT-400 Multimedia Projector
I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit goes back into standby mode before warmup is complete. I've read that it's doing this because the hrs have not been reset. I have repeatedly tried the on, input, undo, left, enter, right, on with no luck. I am unable to reset the timer and cannot use the unit. Any suggestions?
  • 442 Answers
If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
The lamp 0000H is displayed on the lower left of the screen.
Posted on Mar 28, 2011
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    My projector blew a bulb after installation what the problem generic bulb
    Hello :
    Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
    Check for manual here please :
    Sharp DT-100 Multimedia Projector manual .
    Here is how to replace a projector's bulb correctly :
    1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
    2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
    3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
    4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
    5:Reassemble the access panel, repluge the cables and power up the projector.
    Things You'll Need:
    new projector lamp
    screwdriver
    micro fiber duster
    Warning:
    avoid touching the bare projector lamp
    I hope this will help .
    rate please !
    Mar 21, 2010 | Sharp DT-100 Multimedia Projector
    Indicator lights on, no function, no fan, no lamp
    Press the MENU button to display the "MAIN MENU", and then select "OPTION".
    Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
    Press and hold the ENTER button for approximately 3 seconds.
    The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
    Turn off the power and disconnect the power cord.
    This will reset the cumulative usage time for the lamp unit to "0".
    Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
    Flashing green light
    1. Pls check and inspect the Lamp unit.
    2. If Lamp unit is okay, Then the Problem is with
    either with Ballast unit or the DMD Module.
    Regards
    Viren
    May 31, 2008 | Sharp XR-10X Multimedia Projector
    Tech support for Sharp PG-B10S
    Reset The Lamp Timer.
    While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
    Sinista
    Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
    Compaq MP2800 Lamp powers down after a few seconds
    Hi Wayne
    It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
    Mar 22, 2008 | Compaq MP2800 Multimedia Projector
    Sharp DT-400 Multimedia Projector Logo
    154 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
