Question about Brother HL 5140 Laser Printer
Brother HL-5140 red status light on
Hi Just relocated the printer and when I reconnected, the printer just sits there with the red status light on, no other lights. Tried everything, turning off/on but nothing. Can you help please.
  • Anonymous Mar 18, 2014
    hl-5140 brother laser printer red status light
    Genius:
  • 1,689 Answers
RED status light means that there is a possibility that the internal circuit might have got damaged (cracked to be exact). This would require a professional to fix the problem. So, the best thing to do would be to call Borther techsupport because they will instruct you specifically on what to do and what needs to be replaced (also you may need to consult the device's warranty status)
1-877-BROTHER
Brother Tech Support
hope this helps, good luck on this one.
Posted on Aug 04, 2008
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
HL-5140 laser printer, refilled toner and red light still on.
sorry, the only way it is not only refill the toner, you need to change a little chip a green squar, who sold you the toner will can find to you
Jul 18, 2009 | Brother HL 5140 Laser Printer
Brother HL5140 won't print
Sadly this happens all the time - we have about 12 of these printers and 2 have the same problem at this moment and the only fix we have found previously is to replace the drum unit with a brand new one which is hardly economical - indeed the machines are all NHS funded and often the solution has been to throw the printers with this problem away and we have a few defunct ones piled in a corner because of this - if anyone knows why and how this happens ( the tech dept locally has no ideas but just wupply an new printer as they are cheap) I would be very interested also - changing the drum and cartride to a partly used one from a different machine does nothing at all either so it has to be something to do with the chip in the new drum resetting the machine but how and why is beyond us. In every case the printer prints perfectly before the fault and after the change to a new drum so I can only assume it is a way of generating more drum sales??
May 28, 2009 | Brother HL 5140 Laser Printer
Brother HL-5140, Status light is red and toner light is on. Replaced toner cartridge and the same condition exists. Thoughts?
It is very hard to find the reset instructions on the Brother Solutions site.
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Mar 20, 2009 | Brother HL 5140 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Paper
I had a similar problem. I noticed that the paper tension on the paper tray wasn't set correctly. Needs to be tight. Once corrected it worked fine.
Aug 18, 2008 | Brother HL 5140 Laser Printer
Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Feb 20, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
909 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
