Question about GE JN327 30" Standard Range Hood w/ w/ Vertical/Rear Exhaust & Variable Two-Speed Fan Control
We have a GE V330 003AD range hood with a broken fan blade. Are there replacement blades?
  • GE Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Posted on May 09, 2011
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Fan has a humming noise and locking up
a.if there were a dead bird inside, you'd know it from the smell! if the outside vent has the proper hood on it, it's doubtful a bird could get into it. possibly a roof-rat, but still- the smell!
b. have you 'de-greased' the filter lately? clogged filter can cause airflow problems, as well as allowing fan blades to become greased up and unbalanced, which could cause a noisy condition. if you can- remove the filter unit and check the fan blades for crud. use a gentle application of windex, rubbing alcohol, or some other gentle solvent to clean the blades. the leading edges usually pick up the most crud. you should be able to see this! carefully, using q-tips, or a small brush, clean off the crud! the fan's probably out of balance. WD40 works pretty well, too. also lubricates the shaft bushing that the blades are attached to. make sure the fan is turned off! duh!! good luck! also- soak the filter in hot water and a good de-greaser for a while, 'til you can see light through it. it's probably aluminum mesh- so use very hot water and a goodly amount of 'grease cutting' dish detergent. rinse well.
once again- good luck! the filter is probably held in place by clips. once removed, you will probably need a flashlight to work on the fan blades. put paper towels, or newspaper down to catch drips!
Sep 29, 2009 | GE ZV750SY Kitchen Hood
JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Jul 04, 2009 | Jenn-Air JXT8136ADS Kitchen Hood
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fan blades or motor in Nucor over the stove hood
it is hard to get the fan off. but if you are carfull you can do it. but any large home improvment store can help with a new fan.
May 03, 2008 | Kitchen Ranges
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone Allure® I WS136BC Kitchen...
GE JN327 30" Standard Range Hood w/ w/ Vertical/Rear Exhaust & Variable Two-Speed Fan Control Logo
376 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
