Question about LG WM2277H Front Load Washer
Hello ! I have the LG wm2277hs washer machine. the problem that we are having right now is the water leaked after washing. Pleaase show me how to trouble shoot that, thanks
  • 4,323 Answers
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere back of the drum. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly.
Please post back in case of any issues. Hope this helps...
Daniel
Posted on Mar 26, 2011
My lg model wm2277hs won't rinse water stays after washing
you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
Nov 02, 2012 | Washing Machines
How you can replace the water pump motor for wm2277hs washer
Hi Maria.
The pump is located in correspondence of the front bottom side of the machine. Behind the pump filter access.
The pump is screwed to the internal side of the chassis. The procedure to replace the pump is illustrated here.
Aug 13, 2012 | LG WM-2277HW Front Load Washer
Lg washer model wm2277hs does not add water
If you mean that water does not come into the machine at all then you need to have the water inlet valves checked by a qualified Technician for correct operation.
Poppa
http://www.cdbaby.com/cd/poppamadison
Jan 16, 2012 | LG WM2277H Front Load Washer
Have an LG Tromm WM2277HS washing machine the water will not drain and of course will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Washing Machines
I have an LG WM2277HS which will aggitate, but will not spin & rinse.
make sure the door safety switch is working correctly ,, if it doesn't show as locked, the machine won't spin
Jul 15, 2011 | LG WM-2277HW Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Own LG Tromm Wm2277hs
may be the sensor? I have the same model and I changed the sensor now it fills.
Jan 17, 2009 | LG WM-1485FHD Front Load Washer
LG WM2277H Front Load Washer Logo
183 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
