Question about Music
I have a power acoustic 2000 watt amp and a set of power acoustic 10s my amp keeps getting very hot and im scared i will blow it
  • Music Master
  • 5,603 Answers
Make sure the airflow across the heatsinks is not restricted. The airflow should not be blocked by other modules, Also buy fans to force air across the heatsinks,
Posted on Mar 26, 2011
Fuse blows as soon as i turn it on.
You might have a shorted rectifier or capacitor in the power supply circuit. Check that first.
Apr 12, 2015 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
http://www.crateamps.com/support/index.php
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Low volume for a 180 watt amp, does this amp have one 180 watt power amp or two 90 watt power amps?
If there are stereo effects , like chours and delay it more than likely has 2 90watt amps
Jul 08, 2011 | Behringer ULTRACOUSTIC ACX1800 2x8...
The fuse inside the head keeps blowing when i turn power on, and Im getting continuity between the white & black from the transformer
Looks like the main power IC is shorted!
Check the main power amp IC and replace it if there is a short between their pins!
Hope that helps you out!
Jun 23, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Mains transformer keeps blowing fuses
You have a short somewhere & you should get it checked thoroughly else you might receive a electric shock if you connect to your guitar anytime.
Jun 10, 2011 | Hartke AC150 Acoustic Guitar 4x5...
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Hi im in Argentina and i accidentally pluged in my amp without an adapter now it doesnt work what needs to be fixd?
The power supply is blown. Argentina is 220V I believe. I have never seen a power supply schematic for this however being that it is low power it is a linear supply not switching. Either the rectifier diodes are blown out or possibly the output capacitors are blow due to approx double voltage. If you try this yourself be careful otherwise get a new amp. Good Luck
Dec 14, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
After hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Jan 29, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
32 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
