Question about Swatch Skin SFK254 Watch
Swatch Skin #SFK254 ,Time always late
I have a Swatch watch skin type. I found that time is always late so I changed the battery. But even it has now a new battery ,its always late after I set it to current hour. (Sample. If I set it to 12:00PM , after several hrs, it is late already by 7 to 10 min.)
Thanks in advance.
  • steve745 Dec 03, 2008
    I also have a skin Swatch and it runs slow as yours does. I called a Swatch dealer, but he said the watches are made to "replace, not repair." I love the watch, but this is an issue. Any help out there?
  • oldboy10 Jan 09, 2009
    I bought my wife a Swatch Skin watch a few months ago. Within a few weeks it started losing a few minutes each day (tested).
    It was replaced by Swatch.
    This new watch also lost several minutes per day.
    We phone Swatch and they agreed to change it for a different model.
    When it arrived, it was the same model as before which, believe it or not, also started losing a few minutes each day!
    I will now seek a full refund as Swatch have had the watch more than us and after three faulty watches, the company must be selling cheap rubbish from the Far East, or if not, their quality control is non-existent.
    I was in the retail jewellery business for some years and have my Retail Jewellers Diploma therefore was careful to check the watch thoroughly before returning it each time.
    Very poor indeed.
    DCE
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
Posted on Dec 19, 2009
This is my 2nd watch in 4 months and it died again? What can i do to get a watch that works.
I know how frustrating that is, I have to use pocket watches as I have medical devices that emit magnetic charges kills watches and batteries within a few hours. Always had issues as my body has always had strong electrical impulses. Avoid the battery models or try bands that keep the watch body from contacting your skin. Good luck
Apr 14, 2017 | Watches
Tip
SWATCH - SKIN CHRONO settings
Follow this link and see how to set your SKIN CHRONO watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/skin_chrono.pdf
on Aug 04, 2010 | Watches
The date of my Swatch changes in the after at 1.30PM. How to fix this
The time set is 12 hours late. When it changes date at 1:30 pm, advance the time by 12 hours.
Nov 04, 2013 | Watches
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
Aug 24, 2010 | Swatch Irony watch
How to change battery on a swatch skin watch
  1. Place the watch in case holder. Place the watch in the case holder, if you have one. If you do not, place it on a soft cloth.
  2. Check for room to work. Check to see if there is room to attach the adjustable case wrench and rotate it 360 degrees. If not remove watch band.
  3. Remove case back. Fit the adjustable case wrench into the slots on the case back. Tighten it down until it is snug. Be careful not to slip with this tool as it can scratch the case back of your watch. Work slowly. When it is unscrewed gently pry up the case back taking great care not to damage the internal gasket. If the gasket gets damaged it will need to be replaced with the battery to retain water resistance.
  4. Remove battery. The battery will be held in place by some type of retention device. It will need to be removed. Some clips will be removed by using tweezers. Some clips may be moved using a screw driver, and some simply bend out of the way slightly. Remember how it was removed as it must be put back in place exactly for the circuit to be completed after battery change. If the clip is removed, place it and any screws in a paper cup to prevent loss. Remember how the battery was seated, plus (positive) side up or down etc. it needs to be replaced correctly to work.
  5. Test battery. Using the battery tester check the battery. If it is dead move to next step, if it is not take the watch to a jewelers for inspection.
  6. Clean and inspect battery box. Inspect the battery box the battery came out of. If there is corrosion take it to jewelers for inspection. If there is light dust it may be cleaned with a clean soft cloth.
  7. Buy battery. Use the numbers on the battery and buy a new one. Occasionally the number will be obsolete and you will be referenced to a replacement battery in the battery charts. This is the time to also replace the gasket if you need to. Check with a watch maker or jeweler, or the watch company to buy a replacement. We cannot stress enough how important this gasket is to a water resistant watch, without its integrity your fine watch may no longer be resistant.
  8. Replace battery. Using the plastic tweezers if you have them, or fingers wearing cotton gloves, replace the battery. Never use bare fingers as finger oils may corrode or short out the new battery. Carefully replace the retention device as it was remove.
  9. Replace case back. Make sure that the gasket is in place, and not pinched or caught in the case back when you set it in place. Screw down the case back using your fingers until it is tight and needs the case wrench. Attach case wrench as before and tighten down the case back.
  10. Reset and clean watch. Using the appropriate method reset the watch. Use the polishing cloth to clean off any dirt and finger prints.
OR...take to your local jeweler/watchmaker who has the appropiate tools and let them do it for you!!!! :)
Aug 14, 2010 | Swatch Skin SFK254 Watch
How do you open the case of a Swatch skin watch?
the swatches are sealed from the factory.the only that you can do is to change a battery!
May 03, 2010 | Swatch Skin SFK254 Watch
How to change battery in swatch skin watch, how do you get into the back of the watch
Take it to a watch shop. It can be more difficult than it would appear to change the battery yourself.
Feb 10, 2010 | Swatch Skin SFK254 Watch
Put in new battery and it does not run.
It is because some 317 batteries have their negative terminal plate flashed a little bit into the positive side plate and some are a bit thicker thus the negative plate of the skin swatch touches the side of the battery. sometimes battery cove/lid cannot be closet when the battery is a minute thick. renata battery is just right for the skin swatch.
Oct 20, 2009 | Swatch Skin SFK254 Watch
Swatch Skin SFK254 Watch Logo
1,074 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
