Trying to get cd to boot from bios
I'm in Boot priority order:
IDE HDD:
IDE CD:
USB HDD
USB CDROM:
USB FDC:
USB KEY:
  • 5 more comments
  • Evilwoman34 Aug 04, 2008
    After IDE is PCI i left that out.
    do i supose to switch these around put cd first
    ok so put usb cdrom above ide hdd
  • Evilwoman34 Aug 15, 2008
    Thank you very much! You help me out alot. I got it to boot up now. But you know what i am having problems getting it to work. It loaded up now i am getting an error.
    when i put the cd in and it loads up.Then it says
    Candidate Windows partitions found
    1: /dev/sda2 71448MB BOOT
    2: /dev/sda3 67865MB
    But when i hit enter or even try 1 then enter i get and error message thats saids
    FAT:bogus number of reseved sectors
    VFS:can't find a valid FAT filesystem on dev sda2.
    mount: mount failed!/devsda2on/disk failed: invalid arguement
    ERROR:mount failed! try to select another?
    according to this program i bought it supose to so simple lol...this is my luck
  • Evilwoman34 Aug 16, 2008
    i email the ppl and they told me that she believes that i might have a corrupt hard disk. how do i format the hdd? I want to thank you for your time to help me you have help me out then the site i bought the cd from.
    Genius:
  • 1,689 Answers
Just may the CDROM the top priority, then it may ask you to restart the computer, just let it restart then put the CD in.
Posted on Aug 04, 2008
  • 3 more comments
  • marlon john madrid
    marlon john madrid Aug 04, 2008
    IDE CDROM, fi the CDrom is installed IN your computer
    yes put it on top then run it, it will then load the CD
    if you have it running, it will start loading your OS
    marlon john madrid Aug 15, 2008
    what is the error on that?
    if that is the case you must get the HDD formated. you may use another computer or the CD to do so.
6ya staff
SOURCE:
Trying to recover from acer restore cds but keeps coming up with the above eror number and telling me to restart computer
Hello
Can you read the that recovery disk in another computer/laptop? If yes,put the CD into the tray When you boot your system hit f12, then select your USB cdrom, and it should boot then.
If no,you have to check the BIOS settings to ensure that "CD-ROM Drive" is set as the first boot device, otherwise the PC will ignore the disc.
press F2 at the acer splash-screen during the boot process, or when you see "Press F2 to enter setup" at the bottom of the screen.
On the main BIOS screen there is a menu along the top.
Use arrow key to highlight 'BOOT' in the menu bar.
Now you see "Boot Priority Order"
Yours probably has "IDE 0" as first boot device,
and "CD/DVD as second boot device.
The first boot device (IDE 0) is already highlighted.
Press 'F6' to swap them round, so that first boot device is
"CD/DVD"
Now press 'F10'
Highlight "YES" at the prompt (may already be highlighted) and press <Enter>
PC will reboot, this time from the CD/DVD drive first.
You can leave the BIOS set like that permanently so you don't have to go through all that process again next time, just don't leave a bootable disc in the drive unless you really want to boot from it.
Apr 12, 2011 | Computers & Internet
Booting is not working, I already inserted a backup cd, but when doing so, the screen keeps as just blank with an arrow.
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 18, 2010 | Acer Aspire 5050-3242 Notebook
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
Will not boot
Nov 17, 2010 | Computers & Internet
ACER 5520 will not boot from cd or usb and hd is
IN THE BIOS SETUP.
SET THE BOOT ORDER AS
FIRST BOOT DEVICE
CD ROM
Dec 01, 2009 | Acer Aspire 5520-5908 Notebook
I am trying to replace the hard drive in emachine 500is. Now the computer will not recoginize the cd rom to read the windows xp set up disk.
Go into BIOS Setup, and in Boot Order, change the first boot device to CDROM.
How?
To go into BIOS Setup you start tapping either the DELete key, or the F2 key, ->Right After you see the eMachines logo. If you miss this window of opportunity, simple press the CTRL, ALT, and DELete keys, At The ->Same Time.
This will restart your computer. Try again.
If you try the DELete key, and this wasn't the proper key, then use the above, restart your computer, and press the F2 key -> As Soon As You See the eMachines logo.
In the BIOS Setup main menu, look across the top for Boot Options. You cannot use your mouse to navigate around in BIOS Setup, you have to use your keyboard. Press the Right Arrow key to highlight Boot Options, then press the Enter key.
Your BIOS Setup may be different for this model. You may have to go down to Advanced BIOS Settings, in the main menu, and highlight it. Use the Down Arrow key to highlight Advanced BIOS Settings, then press the Enter key.
In the Advanced BIOS Settings sub-menu, look down the list for ->Boot Options. Use the Down Arrow key, and highlight it, then press the Enter key.
In the Boot Options sub-menu, you will see a list of boot devices. Floppy Disk drive, CDROM, HDD, (HarDDrive, or really -> HarDDisk), and perhaps a fourth one.
Use the Down Arrow key and highlight ->CDROM. Look down at the bottom of this menu, and see what the Navigation keys are. It won't state -> Navigation Guide, but that's what it is. You want the -> Change Value, keys.
It may be +/-, or Page Up/Page Down. (Plus + key, or Minus - key)
Using the Change Value key, move CDROM to the top of the list. (You have to hold the Shift key down in order to use the + key)
You may have to highlight the device on top of CDROM, and change value of it, in order to get CDROM to come to the top. Keep moving the boot devices, until CDROM is at the top of the list.
After CDROM is at the top, press the Enter key.
Now press the F10 key to save the changes you made. Now press the y key, and then the Enter key.
If you do not press the F10 key, and then the y key, it will be like you have done Nothing at all!
You haven't saved changes.
You may also have the words -> YES, and NO listed, instead of the Y key. (It's shown as a capital Y for clarity. Press the y key. Do Not hold the shift key down, and press the y key)
You can either use the appropriate side arrow key to highlight -> Yes, or just press the y key.
Now press the Enter key. Your computer will restart.
Your computer will now look in your CDROM drive for a boot disk. (It can be a CD drive, CD burner drive, or DVD drive, or burner)
IF, you do not have the Windows XP disk in your optical drive, or IF you did not get it in your optical drive before the computer booted up, don't sweat it.
Just make sure the disk is in the drive, and then press the CTRL, ALT, and DELete keys,
AT THE SAME TIME. Your computer will restart.
(Not 'shouting')
Jul 27, 2009 | Computers & Internet
Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Jun 14, 2008 | Toshiba Portege R100 Notebook
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Install CD won't boot from cdrom drive
Maybe you need to check the boot process in the BIOS and make sure that it tries to start from the CD-ROM and not the hard drive. Usually, to get to the BIOS (I don't know how much of a tech that you are), on start up, hit the "del" key when you turn it on to get to it. Once in BIOS, hit the right arrow button to goto "Boot" and move down to "Boot Priority Device" and make sure that it goes to your CD-Rom first and then your hard drive. Let me know if you have any further questions.
Apr 06, 2007 | EliteGroup nForce3-A Motherboard
Open Questions:
Computers & Internet Logo
283 people viewed this question
Ekse
Marvin
Marvin
