Question about Samsung HTC550 Theater System
When i put my 5.1 CH Blue - ray Home cinama system on the following letters appear LUHD Then PROT and then it goes of.
    Guru:
  • 1,833 Answers
If you received LUHD and then PROT, that means your system is malfunctioning somehow, and functions are interrupted, because system failure. Try with pressing the BD Receiver/TV Button until it glows a Yellow color, restart your Home cinema system. If you still face same problem consult with tech support, for that you can visit this web site : http://www.samsung.com/us/video/home-theater/HT-C550/XAA.
Posted on Mar 28, 2011
Unsupported mode pops u and i cannot play dvd's.
Check region code, make sure its dvd region 1 for U.S. CANADA! If it's a blu-ray disk then it needs to be region ''A'' disk for U.S. Canada If not you will need a region free player. You can also play them on a Pc or laptop if blue ray disk you'll need blue ray player for your pc or laptop,
May 13, 2015 | Panasonic 1000W 5.1-Ch. 3D / Wi-Fi Blu-ray...
SYSTEM SHOWS ERROR CODE PROT AND SHUTS DOWN
Check the impedance (resistance) on all the speakers and the speaker wires themselves.
Power up the unit with no speakers or inputs attached at minimum volume and see if it still goes into protection mode.
Most speakers should measure between 4 and 8 ohms for most systems when disconnected from the receiver.
If the unit says PROT even with no inputs at minimum volume with the speakers detached, then there's a problem with the amplifier itself, probably in the output section.
Jun 12, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
It does no obey to any commands other than lighting up with the letters (RC1)
RC 1 or DVD 1 is the unit's default remote command mode. You can try the following with the remote:
While the unit is on, pick up the remote, then press and hold [ ENTER/OK ] and the number [ 1 ] button together for 5 - 10 seconds, then release. Repeat the procedure if it makes no difference and the unit still ignores the remote. If it doesn't work, try new batteries, then repeat the above.
{ You can reset the unit if necessary (press and hold [ CH UP ] and [ CH DOWN ] button together for 5 - 10 seconds on the front panel (not the remote), until 'SETUP' appears in the display). }
Hopefully this should help a bit. You should not need to continuously reset either the main unit or the remote.
May 13, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
My system turns on then the word "prot" appears
its protection mode a failsafe put in place to shut down the unit in the event of a possible critical failure .......maybe a fuse.......maybe a dead system your budget will decide what your next step is ok good luck
Dec 17, 2010 | Samsung HT-Z310T Theater System
Need remote code
try this method THIS METHOD WORKS FOR THE CH-DVD 300, CH-DVD 300S, AND CH-DVD 320
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region (0=REGION FREE )AND PRESS ENTER again to save the desired region.
6. Press OPEN/CLOSE. Hope this helps you with your problem
May 02, 2009 | Cyberhome CH-DVD 300 DVD Player
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
It does not want to load anything.
have you tried resetting it to factory defaults?
Jan 10, 2008 | Cyberhome CH-DVD 300 DVD Player
Samsung HTC550 Theater System Logo
232 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
