Question about Boating
Globalmap 2000 sonar not responding
I have a Lowrance Globalmap 2000 and a Lowrance Bluewater in-dash depth sounder - all hooked to a SAM-ST. The bluewater seems rather eratic and I have a message on the Globalmap sonar screen that says "Sonar not responding". Any ideas on how to fix this?
  • Kdkiehn Aug 26, 2008
    Ok, did some more wire tracing and searching and I was wrong - each unit has it's own through-hull transducer. The Bluewater will not read correctly, whether the Globalmap is on at the same time or not. Same is true for the Globalmap and getting the "sonar not responding message." All the connections up front (at the flasher, Globalmap, and SAM-ST) are clean and tight. I can't believe that both transducers would cease to function at the same time. Do the transducers themselves have a ground that could have come loose? I don't want to have to remove the batteries and charge to get in to inspect them unless I absolutely have to - especially in the middle of fishing weather!
    Novelist:
  • 113 Answers
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Posted on Aug 19, 2008
  • Paul Hyde
    Paul Hyde Sep 01, 2008
    All transducer connections are sealed and a cable failure would mean replacing the entire transducer and cable. The only thing I can think of that would cause a simultaneous failure would be possibly a screw from some other installation that happened to pierce both cables at the same time.
    Is the SAM-ST getting power? It should have an LED indicator that lights up when turned on. If it is on make a note of what color it is and how it is flashing. Usually green indicates a working model, and some other color represents some kind of internal failure.
How can a lowrance 5300 globalmap iGPS be used as a fishfinder.
Sadly, the 5300 does not have fishfinder/depth capability.
If you require it, the link below is for the owners manual for your unit.
Sorry I couldn't have given you happier news.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5300ciGPS_0152-191_120506.pdf
Feb 24, 2015 | Lowrance Globalmap 5300c Igps 5" Screen...
Tip
Lowrance X515C Manual Download
Download Lowrance X515C Manual
Models: X510C / X515C
Have you misplaced your Lowrance X515C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X515C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
__________________________________________
on May 06, 2010 | Boating
Tip
Lowrance X510C Manual Download
Download Lowrance X510C Manual
Have you misplaced your Lowrance X510C Fish Finding & Depth Sounding Sonar Owners Manual?
Would you like a digital, searchable, pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar Users Guide?
Follow this link (& click FREE) to download a pdf version of the Lowrance X510C Fish Finding & Depth Sounding Sonar documentation.
I hope that helps.
Can i put lowrance 5hdi sounder and a lowrange sounder/gps 7hdi on the same transponder unit?
If you want to use two head units off of 1 transducer the answer is yes. You will require a transducer switch that allows you to select which head unit receives the sonar signal.
If you want to swap head units utilizing the same transducer the answer is also yes you can do that.
Dec 19, 2014 | Lowrance X515cdf 5" Color Lcd Sounder With...
How do i disable the depth sonar
There is a selection either under sonar options or the main menu sonar tab that allows you to turn the sonar off. Article Details
here is a link to Lowrance to download your users manual in a PDF format.
Oct 17, 2014 | Lowrance Elite-4 DSI Combo with 455/800kHz...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
The screen is the weak point of the 2000's.  I have one myself, and without warning a number of "lines" appeared on the screen, getting progressively worse over time.
Perusing other forums, it seems we're not alone.  Unfortunately the only "solution" I've found thus far is to purchase a new head unit (eBay is a terrific source!).
May 08, 2008 | Lowrance GlobalMap 4800 GPS Chartplotter...
Boating Logo
467 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
