My laptop not charging n its a new adapter - Computers & Internet
    Genius:
  • 1,288 Answers
In this order:
Check (if yours is a Dell laptop) that it is a genuine Dell charger. An aftermarket one will NOT charge it
Then see if it is tight fit, if loose or sloppy, the jack is either the wrong size, or your port is worn. If the latter, you will need to get a new one put in (usually about 4.00 to buy)
Then check the light on the charger, if it is pulsing it means that the charger is not getting through to the laptop (power is being "spat back"), this indicates a faulty charging circuit
Finally, with a DC multimeter set to 20 volts, put one probe into the inner part of the DC JACK (the bit that goes into the laptop) and the other probe against the outer part of the jack. (Red to inner, black to outer). Check the power voltage is 20 volts. If not, the charger is faulty.
After that.. could be battery is unable to accept a charge, in which case replace battery, or there isa faukt on the motherboard.
Posted on Mar 26, 2011
My Dell Inspiron 3520 laptop is not charging, the charger/adapter is not working. I cannot fix it, bought new battery and adapter and they do not charge. What do I do?
Is the plug that you connect the adapter to still properly connected to the mo bo? If not, the adapter will not work nor will it properly charge the battery. Bet that if you charge that battery to another working laptop your new battery will take a charge.
Sep 04, 2017 | Dell Computers & Internet
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
My acer laptop computer will not turn on, charge or anything. the charging cord has a flashing green light but no charge light on the computer.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 11, 2010 | Acer Computers & Internet
Just purchased a new Lenovo battery, and it has never charged to more than 33%, and now is at 0. One icon shows it is charging, another icon says it is plugged in (AC adapter), but not charging...Tried to...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 15, 2010 | IBM Lenovo ThinkPad T61 6466 Notebook
My battery is not charging. Even the new battery says "Plugged in not charging". Why would this be?
Sep 11, 2010 | Dell Computers & Internet
My laptop inspiron 1525 is shutting down suddenly. The battery is not charging. I tried using new battery but still it's not charging. I'm loosing documents and files due to the sudden shutdown of the...
Sep 10, 2010 | Dell Inspiron 1525 Laptop Jet Black
Hi Purchased a new 6cell Li-ion Battery for Toshiba laptop .It is giving backup of 2hrs30min .I kept battery with laptop for 3 months and again i started the laptop not charging .it is charging for some...
Sep 08, 2010 | Toshiba Satellite A135-S2276 Notebook
Battery charges quickly but does not hold charge even with new battery
Sep 04, 2010 | Acer Computers & Internet
Pavillion dv4-1114nr works with newly charges battery but will not work with any adapter or charge the battery.
Aug 31, 2010 | HP Pavilion dv1000 Notebook
My laptop battery hp compaq 2510p is not charging, even with the adapter plugged in. Is the a way to force charge it?
Aug 23, 2010 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Alun Cox
David Payne
David Payne
