Question about G7 Productivity Systems VersaCheck Silver 2008 Full Version for PC
When trying to open versacheck I receive this message: Invalid base 64 decoding value: 'I'
3 Suggested Answers
  • 5 Answers
SOURCE: VERSACHECK
on which, folder you are installing this software is already encrypted, so you will have to install it in new folder.
Posted on Feb 16, 2008
SOURCE: VERSACHECK
You need the following file from the G7 web site. http://www.versacheck.com/update/2002/vcheck7_0_9_1.exe .Follow instructions carefully and Versacheck 2002 will run.
Posted on Jan 24, 2009
What is code 64 as a error message
Error 64,65,66 are related to the same problem
64. (01000000) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency < 66kHz
The Motor Controller module has received signals from the water level sensor (Ptx)
below normal frequency values.
Primary Source: Motor controller module.
Action: Replace Motor Controller module.
65. (01000001) Phase 5 and 6 - Pressure Transducer (Ptx) error frequency > 90kHz
above normal frequency values.
Primary Source: Motor Controller module.
Action:Replace Motor Controller module.
66. (01000001) Pressure Transducer Error [Ptx
Frequency > 90 kHz
Aug 03, 2014 | Fisher and Paykel Washing Machines
Tip
Firefox Tweak to max speed
There are dozens of articles on how to speed up and optimize Mozilla Firefox using various tweaks to the default Firefox settings. I've used Firefox for years now and when I upgrade from one PC to another I always forget my top tweaks I use to make Firefox faster and then have to research them again. So now I'm going to document my favorite speed tweaks here on my blog for future reference.<br /><br />1) Tweak the page render time from 250ms to 0ms.<br />This value is the amount of time the browser waits before it displays the web page. Mozilla applications render web pages incrementally - they display what's been received of a page before the entire page has been downloaded. Since the "start" of a web page normally doesn't have much useful information to display, Mozilla applications will wait a short interval (default: 250ms) before first rendering a page. But with fast broadband connections you can set this to '0' and get a nice speed boost!<br /><br />How:<br />Open the Firefox "config" page: click into the Firefox address location bar, and type about:config, and press Enter.<br /><br />The Config file will appear in the Firefox browser.<br />Right-click, New, integer. Type 'nglayout.initialpaint.delay' and set to '0'.<br /><br />2) Turn on http pipelining, a technique in which multiple HTTP requests are written out to a single socket without waiting for the corresponding responses. This results in a dramatic improvement in page load times. Normally the browser will make one request to a web page at a time, but when you enable pipelining it will make several at once.<br /><br />How:<br />In the about:config page, filter on this text 'pipel', which will display this:<br /><br /><img src="havingline.jpg" /><br /><br />Set your settings as follows:<br />network.http.pipelining: true<br />network.http.pipelining.maxrequests: 8 (screenshot shows '100' but it maxes out at 8)<br />network.http.proxy.pipelining: true<br /><br />3) Increase RAM cache setting value for 'browser.cache.memory.capacity'<br />When images are loaded, they can be cached so they don't need to be decoded or uncompressed to be redisplayed. This reduces the amount of network activity to reload previously viewed messages. This preference controls the maximum amount of memory to use for caching decoded images, messages, and chrome items (application user interface elements). By default it is set to '-1' to automatically decide the maximum memory to use to cache decoded images, messages, and chrome based on the total amount of RAM. Here's the default values depending on your RAM:<br /><br />Physical RAM Memory Cache (in KB)<br />32 MB 2048<br />64 MB 4096<br />128 MB 6144<br />256 MB 10240<br />512 MB 14336<br />1 GB 18432<br />2 GB 24576<br />4 GB 30720<br />8 GB and up 32768<br /><br />The default values are a bit on the low-side. For instance, I have 16GB on my PC, so I can easily bump the automatic 32676 setting to double or even triple that. If you set this to a high fixed value you will see noticeably improved back/forward button performance while going many steps back/forward within Firefox.<br /><br />How:<br />In the about:config page, you can search for 'browser.cache.memory.capacity'. If it's not there, just add it with the type 'Integer' and set the Integer value to a high value. I set mine to 131072.<br /><br />4) This tweak is debatable. I've read changing content.notify.backoffcount can improve performance. What does this parameter do? According to Mozilla, "Rather than wait until a page has completely downloaded to display it to the user, Mozilla applications will periodically render what has been received to that point. Because reflowing the page every time additional data is received greatly slows down total page load time, a timer was added so that the page would not reflow too often. This preference controls the maximum number of times the content will do timer-based reflows. After this number has been reached, the page will only reflow once it is finished downloading."<br /><br />So, if a page reflows too often, it can slow down your browser. This was probably more true when on pokey dial-up connections where some of the images would load but not finish and depending on the size of the image, it could reflow the text incorrectly until another image loaded or the css stylesheet finished loading, etc. Nevertheless, if you want to try this tweak, I read setting it to '5' works well. So Firefox will reflow 5 times, and then on the 6th time, it will just wait for the page to completely load instead of reflowing the entire page again. But if you want to give it a go:<br /><br />How:<br />In about:config, set content.notify.backoffcount = 5<br /><br />5) Enable Windows to swap memory Firefox is using from RAM onto the hard disk. Benefits: Frees up RAM Firefox is using, so that Firefox is only using about 10MB when minimized. As a side benefit, this seems to help with the "memory leak" that Firefox is known for. Somehow when you minimize Firefox, and then restore it, Firefox does NOT use as much RAM as it did previously. So no need to restart Firefox periodically! Drawback: It can cause a delay when the program is restored since it has to read from your hard disk instead of RAM.<br /><br />How:<br />Set config.trim_on_minimize to 'true' (If this doesn't exist in about:config, add it as a Boolean value)<br /><br />So those are my top 5 Firefox tweaks. Now close and restart your Firefox browser and you should see an immediate increase in page rendering, web page transfer speed, and faster loading of all your tabbed windows. Enjoy!<br /><br />Update:<br />Make sure Network.prefetch-next = 'true'. Mine was already set, but just in case, make sure yours is on for the best page load times.<br /><br />
on Apr 27, 2011 | Computers & Internet
I need parts but I can't find my VIN info. Make and model. I tried multiple vin decoders and they all said invalid vin. #L5NPMSCG75TS00316 Please Help me!!! Jen
It comes up as "The VIN you entered (L5NPMSCG75TS00316) has an invalid check digit. The check digit is a value encoded into the VIN in order to protect against altering VINs illegally."
So the bike MIGHT have been stolen, and the VIN altered.
I CAN tell you from the VIN it was made in China, and the model year is 2005.
And the "7" should be a "2"
You MIGHT have misread the "2" as a "7"
IF you put the VIN into a decoder with a "2" instead, I get back that it a "2005 TAOTAO"
Manufacturer:Jinyun County Xiangyuan Industry Co Ltd.
Manufacturer address:No 8 Xinmin Road
Jinyun County
321403 Lishiui Zhejiang Prov
Aug 01, 2014 | Motorcycles
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Serial number for versa check is invalid
Contact customer service.  We cannot provide serials or product keys according to Fixya's TOS
Dec 20, 2008 | G7 Productivity Systems VersaCheck Home &...
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Have just downloaded Cineolayer DVD Decoder Pack 2.3.1. - ESD but when registering won't unlock or recognise Unlock Code to enable me to use it. - Frustrated
Activating Cineplayer
Rate this article: 19_o.gif OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: 000004CP Products: CinePlayer 2.x
CinePlayer DVD Decoder Pack for Windows XP
CinePlayer Decoder and MP3 Player Bundle for Windows XP
OS: Issue While trying to activate CinePlayer/CinePlayer Decoder Pack, you do not have unlock code or you receive an error message:
The code entered is not valid. Please check the code and reenter.
Cause
  • The unlock code is listed as Serial Number
  • The unlock code entered is not complete or invalid
Resolution
  1. The unlock code should be 18 digits long. Please make sure you use zeroes, not the letter O, in the unlock code.
  2. The unlock code is included in your order confirmation e-mail. It might be listed as Serial Number / CD Key in your order confirmation e-mail.
  3. If you did not receive your order confirmation e-mail, be sure to look in your SPAM (a.k.a.Bulk or Junk E-Mail) folders for your e-mail software or webmail client. Occasionally, the order confirmation e-mail will marked as SPAM and will be routed to the trash or SPAM folders. If you still could not find your order confirmation e-mail, please contact Digital River's Customer Service at 1-800-656-5443 or visit
CinePlayer Authentication Error on Launch Rate this article: 19_o.gif OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: 000001CP Products: Cineplayer OS: Issue Users that are not logged in with an account that has administrative privileges may receive an authentication error upon launching CinePlayer Resolution 1. Login with an administrator account
A user account with administrator rights must login and launch CinePlayer to resolve this issue. Once the application has been launched by an administrator other users will be able to run CinePlayer without this error message appearing.
Hope this helps.
Mar 29, 2008 | Computers & Internet
Invalid Battery
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Feb 20, 2008 | Motorola Mobility RAZR V3
VERSACHECK
Feb 15, 2008 | G7 Productivity Systems VersaCheck Home &...
G7 Productivity Systems VersaCheck Silver 2008 Full Version for PC  Logo
130 people viewed this question
Top G7 Productivity Systems Computers & Internet Experts
Jax Planet
Jax Planet
Terry Hair
Are you a G7 Productivity Systems Computer and Internet Expert? Answer questions, earn points and help others
