Question about E-Machines emachines (emachinees) CD-ROM Drive
I think I'm missing the drivers for my disc drives
  • E-Machines Master
  • 27,725 Answers
Make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 26, 2011
If i restored my laptop to factory settings an i think im missing drivers is the a program that will look an c if i got all of them an if i dont it will fix them for free?
You don't say how old your laptop is. Some older laptops came with an Operating System Disc and also a Drivers/Apps Disc. Both would need to be installed to recover to factory settings. If you recovered from a recovery partition on the hard drive, then the drivers should already be installed. Yes there are online services that will scan your machine and install drivers.....many are spam and spyware-ridden. You should simply look at the Device Manager and look for errors that indicate missing or improperly installed drivers. There may be an issue if the network driver is missing, because then you won't be able to get to the internet. Once you know what you need, if you go to the manufacturers website, you can almost always download the needed hardware drivers and install them yourself.
Feb 07, 2015 | Computers & Internet
Driver not found
Disk drives get their drivers as a part of the windows operating system They are all standard.
What makes you think you need a disk driver? what is happening?
If your disk drive missing the driver it will not boot up, so how do you know it's missing a driver?
I'm betting the drive had gone belly up.
Jun 03, 2012 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Drivers lost for the disc drive. error mssg. in
This is probably something caused by a virus and I suggest to reinstall teh operation system ..This will take care of the disk drivers as well ..cause usually the disk drivers are installed with the operation system,..
I think this is an error caused by a virus that attacks the optical drive driver and makes it disappear ..reinstalling the OS from a boot-able disk will fix it ..may sure you save all drivers from the support site before ..so that you will have at least the LAN driver to install and be able to connect after this..
if it refers to the raid drivers or so ..but still works ..eitehr disable teh raid in bios ..or reinstall them all
Nov 22, 2009 | Toshiba Satellite M45-S331 Notebook
I only bought my acer aspire 6930 i couple of months ago and recently it has started to play up. It won't read any discs I put in it. When i go to play them it just says please insert disc. I've tried...
rol back the driver, go to the website for the manufacturer that makes your computer. there will be a list of drivers you can download and download a older one and install it. another this is use a cleaning disk. there might be to much build up on the lens. if neither of those work then the drive is toast.
Oct 01, 2009 | Computers & Internet
Disc Drive won't read after upgrade to Vista Ultimate
I had a disc Drive that wouldn't work for a while. There are a few things that could be wrong. The first thing I would try is to make sure it's pluged in all the way to both the Motherboard and the Disc Drive. Maybe it wasn't secure in there and when you bumped you computer just a little bit, it got unpluged. The wire connecting the Disc Drive to the Motherboard is probably your thinkest wire, can't miss it.
this next thing I would try is to delete the driver for your Disc Drive and then restart your computer. It should detect it automatically and have it running correctly.
If all else fails, go to Google. Type in the name of your Driver and search for an install that is supported on your operating system.
Jul 07, 2009 | Acer (4432A-002) CD-RW Burner
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
Jun 18, 2009 | Computers & Internet
System Restore (Destructive) GM5084 Gateway Media Center w/ XP
what operating system disk do you have? xp, xp pro, vista?
Dec 26, 2008 | Gateway GM5084 PC Desktop
Unable to play cd/dvd on my laptop
LINK
This is a dvd player codec.
LINK to sony support for tool necessary for dvd to read
May 19, 2008 | Siemens Computers & Internet
Toshiba satellite notebook dvd/cd player
Try to get an Windows XP or Vista CD.
Boot the computer with the cd on drive.
Be sure to select to boot from CD in setup(F2 key I think) or boot menu (F9 key I think)
If the computer boot from CD, probably you have a software problem, else your drive is damaged.
Good luck.
Dec 19, 2007 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
