Question about KitchenAid A-9 Electric Burr Grinder
Can not turn the grind wheel - forgot how to do it. It has been on medium grind so long, now want fine grind
    New Friend:
Same thing happened to me. It turned out the cause was a build up of hardened coffee grounds. We took it apart (a bit tricky!) and cleaned it. Now works like new.
Posted on Nov 20, 2012
2 Suggested Answers
SOURCE: Grinding Noise
sounds like you have a problem with the cooling fan
Posted on Dec 31, 2008
Why are black particles being dispensed into the hot wqter from my Keurig coffee maker? How can this be corrected?
Hello, Irwin -
Those "small gritty black particles" are most likely coffee grounds which are so small they slip into the hot water and eventually the brewed coffee.
The grind size of your coffee may be too fine. Drip coffee method coffee makers, including the Keurig, require medium or medium-fine grind coffee.
Source of information:
Coffee Grind Size: Why It Matters and What You Should be Using, by Taylor Martin, December 22, 2015
CNET Best Products
https://www.cnet.com/how-to/coffee-grind-size-why-it-matters-and-what-you-should-be-using/
You may wish to check your coffee maker to determine if coffee grounds leaked into the space between the k-cup and the k-cup holder:
https://www.youtube.com/watch?v=jZrQhlQpLbs
Best wishes.
Mar 12, 2012 | Coffee Makers & Espresso Machines
When I just have water in the portafilter it runs through fine. When I put the expresso in it clogs and expresso will not flow through.
No solution here. Utopia directions say to only use MEDIUM (drip) grind. Ain't it awful? I prefer ultra fine grind, frankly muddy coffee.Deb
Jul 10, 2011 | Starbucks Barista Utopia
My mazzer coffee grinder brings out medium to almost a whole bean grinds ,,,am trying to get a fine grind(for the espresso) but it's not working ,,, i've tried to move the scale to all the numbers but the...
Lets do this, remove the bean hopper, and make sure there are no beans in the burr chamber. Then looking down at the collar with the numbers back up screw if there is one on it. Now if memory serves me right clockwise is coarse and counter is fine. Look down in the burr chamber, notice the nut in the middle, turn it with your fingers that will move the bottom burr, if burr turns freely we will move on if not plug in grinder and let it grind out remaining beans. With beans gone unplug grinder, then turn collar towards fine until you cannot go no more, now try turning nut it will be hard if not impossible to move, turn collar towards coarse until you can barely move bottom burr with fingers, you will hear and feel the burrs touching, that will be our bottom setting. Now pick a spot on the grinder you can use the small notch in the middle, count out 16 notches towards coarse and turn collar to that point. Use the notches around the collar not the ones on the top next to the numbers. Your grind should be almost perfect, depending on blend and machine you might have to adjust 1 notch to the left or right after testing.
Aug 11, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
My 1988 K1500 four wheel drive has grinding sound, 2wd works just fine, only when I engage the four wheel drive does it make grinding sounds, and the left front turns roughly and irregulary. I think I...
im having the same problem... 2wd works fine, 4wd lo and hi both when the engine is just above idle and the wheels spin there is a knocking and when it goes too fast its like a grinding.... ive been told it was the actuator... but ive yet to test that theory... let me know what u find out on that... id sure like to get mine fixed too
Apr 17, 2010 | 1988 Chevrolet K1500
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Grinding Noise
Dec 31, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Won't agitate and makes a grinding noise
hi thanks for the question yes it is a bad transmission sorry
Sep 25, 2008 | Maytag PAV2300 Top Load Washer
KitchenAid A-9 Electric Burr Grinder Logo
378 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Carmen Mikulic
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
