Need procedure to remove drum.to replace seal on button of drum. its leaking
  • 4,323 Answers
Hi
Before disassembling the drum and replacing the drum seal please unplug your washer. Also remember to disconnect inlet water hose and drain hose. Check this video for drum seal replacement--
Hope this helps... Please post back if you more information.
Daniel
Posted on Mar 26, 2011
How to change door seal on miele w698
Normally they're held on with 2 wire rings, 1 at the edge of the seal at the door opening and the other on the edge of the outer drum. Unplug your machine and remove the lid, this will help access and give you more light to work with. Remove the ring at the door opening first and pull seal from the lip. Access can now be made for the one at the drum. Do the same for the one on the drum.
When putting in new one reverse the procedure and start at the drum, make sure you have the seal the right way around, normally holes in bottom of seal for drainage. Thread the seal over the lip and then put ring on. Same process for the front. Put lid on and plug machine in and test for leaks.
Dec 29, 2012 | Washing Machines
Replacing door seal on w698 miele
Dec 29, 2012 | Miele W865 Front Load Washer
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
How to replace grease seal on rear axle
Leaking oil at the rear wheels can be one of two things, Easy fix is brake fluid, this would be the rear brake wheel cylinder leaking. Check your brake fluid tank under the hood for low fluid. If that is ok. Your leak may be your rear axle shaft seal. You need to remove the tire/wheel ether way. Jack up the car to pull the wheel, take your lugs loose while the tire is still on the ground, it is easy to take them loose this way. Take the EM: brake off, and jack up this side of the car. Your car could have disk or drums as both are offered on some Dodges. Once the tire is off you will see if you have disk or drums brakes. If drums you will need to pull the drum off at access the brake cylinder to see if that is leaking or not. If drums you have to back off the brake shoes by the adjusting wheel thru a small access window in the back plate. If you have disk brakes the caliper is right there and will be easy to see if it is leaking. If you have determined it is the rear axle seal leaking, this may be best done by a shop, due to needing a few special tools to remove the axle and then reinstall a seal. You will need a slide hammer. If drum brakes you will have to remove the brake backing plate, this means shoes and all hardware, please take pictures and get as good focus as you can to see how everything goes back together. Once down to the axle mounting, remove the 4 bolts and attach the slide hammer and pop out the axle, catch any fluid that will leak out, once out you can determine which type of seal set up you have as some have press fit collars that may have to be cut off. . Hope this helps FixYa up.
Sep 12, 2011 | Dodge Ram 2500 Cars & Trucks
Left rear axle leaking - Dealer states $820 to fix due to many parts within the axle. Does this sound right?
fix same problem myself...these's' only 1 inner seal (differential output seal only-about 10$ each) that needs to be replace and new brake shoes (20$ part)..assumed u have rear drums and it leaked diff fluid on the brake shoes..but, i also replaced the brake cylinder (15$ part)-u have to disconnect brake cylinder to remove axle..look on internet for procedures..http://www.yotatech.com/f128/replacing-rear-axle-seals-3rd-gen-4runner-76339/..hope this helps..all dealers are ripoffs-worked at toyota for a year
Jul 31, 2010 | 1999 Toyota 4Runner
LR wheel seal leak
these trucks comes withouth c-clip, remove the wheel, remove the drum, remove 4 nuts holding the bearing and pull it out you will need a bench press toremove the holding plate and bearing to replace the seal.
Jul 09, 2009 | 1997 Chevrolet C1500
Rear Axel Seal Leaking, How do I pull the axel to repair?
You will need to remove the differential rear cover,drain fluid, remove wheel, brake drum, (rotor) . Unbolt center diff. pin, carefully remove (don't loose shims) push axle in remove lock keeper, then slide out axle, replace seal, put some grease on it, slide axle in reverse all to install.
May 22, 2009 | 1999 Jeep Grand Cherokee
2 issues.\1st is the truck has dual fuel tanks and
The only way the empty tank could leak is that the switch that controls the two tanks is pumping fuel into your empty tank. This is a common problem with the Ford trucks. In fact Ford had a recall on these to replace the switch for this very problem.
Problem 2: The F-250 you have probably has a full floating axle in it. Remove the wheel. Remove the brake drum. Remove the 8 bolts on the end of the axle stub. Remove the axle. Then you will need to remove the large axle lock nut and the lock ring under it. Then remove one more axle nut. Carefully remove the hub and dont let the outer bearing drop to the floor as it might damage it. Flip the hub over and remove the old wheel seal. Check the bearings. If o.k. put them back in the hub. Install the new wheel seal. Then reverse the disassembly procedure to place it all back together. When finished refill the differential. And be sure to clean the oil from the brake drum and replace the brake shoes if they are contaminated so badly that you can't get them clean again. No special tools needed. Just a good all around assortment to accomplish this task. If you need to purchase tools it would be a good investment anyway. Tools never go out of style. They have uses over and over and pretty much pay for themself.
Mar 03, 2009 | 1993 Ford F250
Replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Jul 19, 2008 | 1999 Hyundai Sonata
Leaking from main shaft
you need to take the panels off, and then detach the drum. not easy..as long as your in that deep, might as well replace the seals.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
