Question about eMachines ER1402-05 (884483174195) PC Desktop
ER 1402-05 Upgraded to 4GB RAM and 500 GB Samsung HDD Everything working fine for about a month. Now on Boot, BIOs will not detect my C Drive - not sure what to do next
  • 36 Answers
Try looking in your BIOS, look for anything that indicates that it see's your hard drive at all. You should be able to see the hard drive size from the BIOS, if not, check the power and data connections inside your computer. Does the hard drive power up? If you don't feel it running, it could be that it has died.
Posted on Mar 27, 2011
Cant install any boot disk to my new asus sabertooth mb
If you can get into the BIOS then your computer is working. The most likely fault is the HDD settings make sure you try with AHCI selected as well as with any other settings. You don't say if the HDD is showing in the BIOS. Check all of your connections are good and, especially your drive connections. Make sure the Boot priority is Optical drive before HDD.
Apr 04, 2013 | ASUS Computers & Internet
Hi, i have an advent t9408 thay i bought off a friend with now hdd or ram so iv added 2 gb ram and a spare hdd i had, now it will not boot at all not even to the bios option screen, i managed to get it to...
First read articles on "ESD".
Link:
http://www.computerhope.com/esd.htm
Look for any warnings or post messages during boot sequence
1. Verify the RAM are the correct modules for your computer.
2. If the RAM is correct then remove 1 stick of RAM
3. Check the jumper settings on the HDD to verify Master, Slave, or Cable Select.
4. Remove the hard drive and verify the system will post.
5. Reinstall the HDD and boot to Bios and verify all devces are detected.
6. You might reset the Bios with the J2,3 to the J1,2 jumper.on the mother board.
Troublshooting is a process of elimination. Start barebones and work your way up!
May 14, 2011 | Computers & Internet
Toshiba Satellite Notebook M45-S351 I recently purchased an upgraded hard drive - 160 GB Samsung Spinpoint and upgraded the RAM (Crucial 1 GB, bringing the total to 1.5 GB of the allowable 2 GB). Impetus...
Remove thwe new RAM and hard drive. Does it boot to the BIOS menu? If yes, add the hard drive and do the same again then add RAM and do the same.
I suspect something does not fit in properly. Probably the RAM.
Don't forget to initialise the hard drive if trying to format it. The System disk should take care of that.
Dec 21, 2010 | Toshiba Satellite M45-S351 Notebook
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Hard drive not working
hi im josh in cebu phils.Friend if that happens whrein your 2nd hdd dont detect. Try to use these solutions. Check first the jumper of the hardisk whether it is stated as slave or master. if 2nd disk is master the jumper should be in the master and if it is slave the jumper must be slave. or try to use another IDE cable. put them as both master the first hdd in first ide slot and your 8 GB 2nd hardisk in 2nd slot as master also. or try to enter bios setup utility then try to check or detect the both device.thats all good luck
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
eMachines ER1402-05 (884483174195) PC Desktop Logo
212 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
