Question about Sony Handycam CCD-TRV21 Camcorder
I have a SonyCCD-TRV21 and the casettte tape wont eject.
    Sergeant:
  • 347 Answers
Hello flame!
possibilities:
no power - recharge battery or use power supply (might also battery broken)
tape stucked - ccd must be opened and cassette must be released manually (might also casette mechanism broken) this is service issue.
regards
Thank you for using FixYa! A four thumbs up rating is appreciated for answering your FREE question.
Posted on Apr 10, 2011
My sonyccd-tvr68 head needs cleaning. is there a kit to clean it
hello frank!
there are some cleaning tapes available at the market. please check your local store. be careful when using them, read instruction manual not to harm heads due missusage.
regards
Thank you for using FixYa! a four thumbs up rating is appreciated for answering your FREE question.
Apr 05, 2011 | Sony Handycam CCD-TRV68 Camcorder
Tape wont eject
From the tape library console, on the menu, select the slot view option, find out the slot of the tape you want to eject. Then move the tape in that slot to the male slot using the 'media move' option menu. The tape will be now ejected to the male slot.
Please come back and post your ratings if this solution helps you in anyway. Thnx
Mar 16, 2010 | HP StorageWorks DAT 72 Tape Drive
Tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Aug 14, 2009 | Sharp VC-A560U VHS VCR
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Tape will not eject
I had the same problem and I switched to smaller tapes. I had been using the 120 minute tapes. It seemed like the tape would lock up after a short while with the larger tapes.
Apr 05, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
Jul 23, 2006 | Sony Handycam CCD-TRV107E Camcorder
Video Cameras Logo
168 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
