Question about Casio PAT2GP-1V GPS Receiver
I' am trying to charge the watch but i can't. How i can found a new battery?
  • 3 Answers
We will have stock of these type of battery very soon.
Keep checking the web site:
http://www.simplesite.com/CASIOGPSWATCHBATTERY
and leave your details. I will contact you as soon as we have them in stock,
Posted on Apr 07, 2011
Battery not charging on 1997 chrysler concorde 3.5L
Look
You have to check fuses one by one .
And watch the battery volt.when you remove the fuse watch the battery volt if it comes normal then you found the problem.
Sep 17, 2017 | Cars & Trucks
Parasitic drain on the charging system
There are plenty of web sites including You Tube Video,
where you can learn how to test for current drains & watch
how to do it
Mar 06, 2013 | 2000 Chevrolet Malibu
Backup power ends quickly even with new battery
What is the load on the unit? How old is it?
The symptom can occur if the load is too large. It will also happen when the unit reaches a certain age.
I've found that the low-end consumer UPS's should be replaced when the battery fails. The charging circuitry usually fails to charge the battery even with a new battery soon after the replacement.
The way I check if the battery or the UPS charging system has failed is with a voltmeter to give the current voltage and a variable DC power supply (whatever is appropriate for the battery) to attempt to charge the battery. I can watch the battery discharge with an oscilliscope if I want a full trace of the unit.) Charge the battery fully then watch the unit over time. If the battery itself is bad, you won't get the full charge or it will discharge as soon as it is removed from the power supply.
I hope this helps.
(the server UPS's tend to be a better choice if you want to replace the battery and keep the UPS.)
Aug 21, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
My MTG900 says, "Charge" on the screen...I got it last Christmas, does this mean I need a new battery?
CHARGE means you have to charge the watch. It depends on what type of movement you have. If it's solar powered, you need to leave your watch under the light to charge it. If it is battery powered - you haqve to buy the new battery and fit it. Rate me,plz.
Feb 04, 2010 | Casio Atomic-Solar MTG900 Watch
My kodak easyshare M320 isn't charging with the USB cord and my camera won't turn on either because there's literally zero battery left.
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 28, 2010 | Kodak EasyShare M320 Digital Camera
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Dec 26, 2009 | Pulsar Watches
Eco-drive BT0054-59E not charging.
I know what the manual says, but I have found that sometimes it can take a few days to charge.
I set mine directly under a UV lamp for at least a day to charge. I have found the PULLing the STEM OUT and setting it under a lamp to charge works the best. Try for a couple days, one day stem out another stem in.
If it still does not charge it may need a new secondary battery.
Citizen offers a good warranty on that secondary battery/ power cell and if it's just a few years old they should replace it for free.
This really is not something you should try to fix yourself as the cells are easy to mess up.
Good luck.
Oct 23, 2009 | Watches
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Citizen Eco Drive
A "non" fully charged watch will sometimes "jump" seconds rather than indicate one second intervals. Charging these small solar panel watches takes forever, in BRIGHT sun. Have you tried leaving it outside, in the sunlight, for at least 12 hours?
Jan 05, 2008 | Citizen Eco-Drive BL006056H Wrist Watch
Casio PAT2GP-1V GPS Receiver Logo
182 people viewed this question
Top Casio GPS Experts
Will Halftowaite
Are you a Casio GPS Expert? Answer questions, earn points and help others
