Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer whirpool
I have water in my tub after wash cycle
  • smokebear45 Aug 09, 2008
    thankyou,thankyou,thankyou! you have been most helpful.your solution worked great! Removing standpipe end to remove all the water saved me a major cleanup to,not to mention you probably saved me a $150.00 plumbing bill.thanks again smokebear
  • Anonymous Mar 31, 2014
    drum fills up with water when washer is off
  • 172 Answers
Hi smokebear,
You most likely have a blocked pump. remove the front bottom panel from the washer. You will need some torx bits screwdriver to remove this. When you remove the plate you will see your pump right in front of you. It has a large removeable filter that you can clean out. Be careful, water will come out when the filter is unscrewed so have a pan or towels ready to catch it. You will probably have 3 or more gallons come out. Unscrew it slowly and catch the water then tighten back up untill all the water is gone. Good luck to you and I hope this will FixYa.
Mike
Posted on Aug 04, 2008
  • Michael Anderson Sep 30, 2008
    Glad I could help smokebear, and thanks for the rating.
    Mike (Owner)
    Anderson Appliance
    (865)945-3808
Replacement: tub seal bellow/Whirpool Duet mod.#GHW9150PWO
Hi
Thanks for using FixYa. You can buy the tub seal bellow for your Whirlpool Duet from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet is making a clacking noise on the spin cycle.
Reach inside and see if there is any play to the inner/spin tub (up and down) . Tub may be seperating from mounting and spindle assembly.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reset the 'Conrol Lock' on a Whirpool Duet Washer?
press and hold the end of cycle signal button for 3-5 seconds
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Whirpool Duet won't spin clothes at high speed
Thinking of 2 things either the transmission is out or the clutch is burnt out and the drum basket and possibly the drive shaft broken as well. Prices vary greatly by how many of these things are broken but should run between 100-200 including labor.
Dec 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I see a code "F/H". Could that be it? If not, please report this in the Washing Machine section.
If so, here is the explanation:
Condition
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HAVE A WHIRPOOL WASHER MACHINE TWO AND 8OR 10 CYCLE- EACH CYCLE THE WASHER IS RENEW THE WATER (40 GALLONS) I DON'T KNOW IT IS NORMAL OR SOMETHING IS WRONG
I would cheak your drain hose it has to be higher then the tub.It may syphin it self out and water will keep coming in Good luck:)
Oct 19, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal De
