Question about Woods Outdoor Photoelectric 24 Hour Mechanical Timer (2001)
My woods 13360 timer blinks on and off - Woods Outdoor Photoelectric 24 Hour Mechanical Timer (2001)
My files do not show Woods 13360.
I am very interesting to identify your timer.
If you have outdoor timer, then timer photoeye can be getting feedback from surrounding lights.
If you have indoor hardwire timer, then white and red wires are probably connected incorrectly.
1) Open following link to identify timer and download manual, and then add a comment and say which timer resembles your timer. From there I can add a comment with possible solution.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
2) Add a comment with photograph of your timer so I can identify timer and add possible solution.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
3) Add a comment and fully describe every aspect of your timer so I can identify and add possible solution.
4) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 27, 2011
Noma outdoor timer with hour and program button that plugs in
Noma is a brand name that generally applies to Woods timers, but it is also used by other companies for various products.
Manuals and resources on following links:
http://waterheatertimer.org/Woods-timers-and-manuals-old.html
http://waterheatertimer.org/Outdoor-timers.html#13360
Oct 25, 2017 | Hardware & Accessories
Lights blink when in manual mode
If this is new installation, then Timer is wired wrong:
If timer worked before, then it has gone bad, buy anotyher timer
Copy following links to identify type of timer, single-pole, 3-way etc:
http://waterheatertimer.org/How-to-wire-timers.html
Gene
hh
Sep 24, 2013 | Woods InWall 7 Day Digital Programmable...
I just installed a Woods Digital In-wall Timer Model #59018. When I switch the power and manually turn the power on, the lights rapidly flash on and off. This is a three-way outlet and I have red, black...
3-way outlet or 3-way switch?
Woods 59018 only replaces single-pole switch, and does not work for 3-way application. Often connecting timer wrong will cause lights to blink. No harm done to lights, timer or wiring.
There are several timers that work with 3-way. In each case the timer replaces 1 switch and other 3-way switch must be rewired.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
http://waterheatertimer.org/ST01C-program.html#3-way
Gene
Aug 03, 2013 | Hardware & Accessories
Lights are blinking after setting up the timer
You connected white wire and red wire together.
No harm done.
ez to fix.
Woods 59018 is single pole timer.
Copy following link to see step-step for wiring single-pole timer:
Add a comment as needed
Jul 08, 2013 | Coleman Cable Woods 59018 InWall 7Day...
Brinks out door timer with photo cell
Make sure photo eye is not exposed to the light, or it will blink or not function as expected
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Brinks makes very cheap timers. Return to Walmart and buy better brand such as Intermatic, Tork, GE, or Woods since these timers are supported by known websites and companies
Jun 20, 2013 | Hardware & Accessories
Model 272625
Timer is not identified.
Copy following link to help identify timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add a comment and describe timer in detail. Attach a photo.
Buy another timer and return defect in new package.
Jun 11, 2013 | Hardware & Accessories
Just installed the programmable timer and had programmed the clock and on off times. Then realized that it was set for AM instead of PM. Hit reset and now can't set the clock or program. Just blinks...
I test timers.
Some arrive defective, and some go bad quickly.
Industry standard is 1 year limited warranty.
All these timers have reset button that should restore functionality.
You posted under Woods digital programmable.
Open link to download on-line manual and read ez wiring steps.
This timer is reset by pushing reset button, without pushing any other button.
Some timers require on-off button to be pushed while pushing reset button.
I suggest turning off power to timer and see if that 'resets' timer.
Otherwise open link below and run through troubleshoot checklist, and also double check wiring.
If timer will not function correctly, then exchange for new timer.
Resourceful do-it-yourselfer can buy similar timer at Home Depot located near light fixtures and doorbells.
GE15086 -or- GE15071 with daylight savings time.
Advantage is ez exchange if problem occurs, and you give yourself extended warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Mar 20, 2011 | Woods InWall 7 Day Digital Programmable...
After installing the light blinks when on. Tried reversing wires and this did not work.
You posted under Woods 59018 timer.
1) This timer is made to replace single pole switch only.
2) If lights are blinking, then wiring is suspect. Probably the red and white are connected together.
Open following link to confirm this is your timer and read ez wiring steps and see on-line manual.
The wiring steps work for all brands of in-wall 7-day timer except those timers that can be used for 3-way switching.
3) Page also lists timers that can be used for 3-way switching, for example in hallway where 2 different switches control same light. List of timers has links to each timer and manual.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 02, 2011 | Coleman Cable Woods 59018 InWall 7Day...
I have a 59028 timer, and when I turn the lights on they flash - versus staying on.
59028 is a Woods in-wall timer.
See Woods timers and manuals:
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
The lights are blinking so the red and white wires are connected together.
Here's what to do Switch has 2 wires.
1) Green wire connects to bare copper
2) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 20, 2010 | Hardware & Accessories
Woods Outdoor Photoelectric 24 Hour Mechanical Timer (2001) Logo
136 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
