Question about Samsung PN58C8000 TV
I have a pn58c8000 and sometimes the sound has problems. I can never predict when the problem will happen. The sound will become very high pitched and everyone talks in high squeaky voices like only the high frequency sound is passed through. The sound returns to normal after a few seconds or minutes.
Make v reset press the exit button on remote for more than 10 sec message reset will appear select yes tv will turn of turn tv back on and select home use this could repaire your problem
Posted on Mar 28, 2011
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
High pitch screeching on my pc cannot fix thru speakers check ok
Unusual noises coming from your computer can mean anything from serious trouble to no problems at all. The uncertainty, together with the expense of computer hardware components -- not to mention the risk of losing data and being without your computer -- make it important for you to investigate any unusual sounds as soon as they come to your attention.
Normal Sounds
Not every high-pitched sound coming from your computer suggests a problem. Computers also generate a variety of sounds as part of their normal operation. In particular, anything that spins can easily make noise. This includes cooling fans and the hard drive. In the case of fans, their sound sometimes grows louder when the computer works harder because it needs to run the fans at a faster speed in order to dissipate the extra heat from the higher level of operation. You probably don't need to concern yourself with an unknown high-pitched sound unless you have used the computer for a while and the sound is new. b> Capacitors Capacitors sometimes make a high-pitched buzzing sound, either when under a high load or when defective. In the latter case, faulty construction can cause gas to build up inside the capacitor, which then vents under pressure and sometimes creates an audible noise. Defective capacitors can damage or destroy other hardware. f you suspect a bad capacitor, or don't know what else it might be, give your computer an inspection. b> Capacitors Inspection b> Your computer has capacitors all over it, including on the motherboard and on nearly everything that plugs into the motherboard, so tracking down a bad capacitor can take some time -- especially if you don't know whether a capacitor is actually causing the problem. Many capacitors look like tiny little soda cans and smaller ones look like squat cylinders. Failed capacitors usually bulge out at the top or have crusty residue around them. Be sure to check not just the motherboard but also any other hardware components with visible capacitors on them. If you find a bad capacitor, keep looking in case you find more. Afterward, don't use your computer again until you repair or replace the faulty hardware. Fans b> The bearings and motors on fans sometimes go bad. If this happens then the fan may begin to whine, whether or not it stops working. If feasible, open the side panel of your computer tower with the system running and try to pinpoint the exact source of the sound. If you can determine that the noise is coming from a fan, power down the computer and replace that fan. b> Power Supply Unit b> Power supply units sometimes make a high-pitched whining or droning sound; it can happen continuously, when you perform certain tasks on the computer or when you take the power load high enough. This can happen either because of cheap construction or because the unit is too close to maximum capacity. As you would do to check the fans, open the side panel while the computer is running and put your ear up to the PSU. If this is where the noise is coming from, replace the unit with a high-quality model and upgrade to a higher power output if you need to do so. Hope this helps.
Jan 08, 2013 | Acer Aspire Z3100 (2771498) 21.5 in. PC...
High pitch sound coming from back of TV?
it could be either the coils on the yoke of the tube or the flyback. flyback would need to be replaced it that is the problem
Apr 19, 2009 | Curtis-Mathis CM19011 TV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
High pitch crackle buzing sound when set turned on
Did you find a solution because I have the same problem on my JVC?
Nov 14, 2006 | JVC AV-27530 27" TV
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
Samsung PN58C8000 TV Logo
169 people viewed this question
Jerry Greenberg
Jerry Greenberg
