Question about Miele CVA 4066 Stainless Steel
I am registering my Miele cva 4066 and need to know where the serial number is located on my machine.
Ya1da
  • 4 Answers
SOURCE: can you give me the process to descale the miele cva 615 coffee machine?
Here you go just click on this link I put the manual on my site: http://yalda.us/CVA615_us[1].pdf
Posted on Mar 12, 2008
SOURCE: display message - brewunit block - can not undo to
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Posted on Jan 21, 2010
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
  • 177 Answers
SOURCE: parts list and drawing for a miele CVA 620 coffie
you would have to contact Miele spare parts for this information it is not readily available on the internet.
Posted on Aug 18, 2010
My Miele CVA 4066 is stuck in descale mode.
Does it stop in the step where it tells you to remove the drip tray and empty it - you reinstall the drip tray and nothing happens?
If you reset power - does it start the Descale process all over?
Dec 17, 2017 | Miele Coffee Makers & Espresso Machines
This is for a Miele CVA 4066 coffee system. When I press on nothing happens. It seems like it does not receive the message that I want to turn on the machine. Nothing happens.
Check power is connected to machine and the internal power switch is on. If this has been done then its an internal power supply/ECU fault. Reagrds
Dec 25, 2016 | Miele Coffee Makers & Espresso Machines
Miele CVA 2660 coffee Maker. Was getting Empty Drip Tray errors. Drip tray contact springs are corroded & broken, no longer reading. The numbers are 06579921 & 06603101. Cannot find parts, help!
Well if you know the part numbers you can try buying them directly from an authorized repair station . Some will not sell you the part because they want to do it for you and soak you at the same time.
If you have the part numbers you can try locating them on ebay or google for them and/or equivalents.
Mar 12, 2016 | Miele Coffee Makers & Espresso Machines
Coffee makers Miele cva 4066 stuck on fit jets in central spout
You might need to reset the coffee maker by turning it off and then turn it on again.
Apr 28, 2015 | Miele Coffee Makers & Espresso Machines
Miele brew unit
You should be able to, If you can remove it and providing there are no Electrical parts, then soak in a white vinegar and water solution.
Or a Descaler.
Jan 28, 2014 | Coffee Makers & Espresso Machines
Drip tray error
Joe -
Try removing the tray and drying the contacts on the back of the tray with a towel. Once dry take a pencil eraser to them and clean them throughly.
Put tray back in and test.
Hope this helps
Dec 07, 2013 | Miele CVA 4066 Stainless Steel
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Miele CVA 4066 Stainless Steel Logo
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
