Question about JBL EON15 G2 Main / Stereo Speaker
My jbl eon15 g2 is making slight popping crackling sounds every so often. What could cause this?
4 Suggested Answers
SOURCE: JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Posted on Sep 21, 2008
SOURCE: JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Posted on Oct 26, 2008
  • 18 Answers
SOURCE: My JBL Eon15 g2 has a cracklin sound within the
it can be the amp or the speaker itself. it has to be diagnosed by a service center.
if the amp is the problem, there can be board replacements or component level repair. if it is the 15" speaker, then it can be reconed with authentic genuine JBL parts returning it to brand new. cathy@speakerex.com
Posted on Jun 25, 2009
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
In turning up volume on eon g2 15 I get crackle sound and then when I mess with switch it finally works. The speaker has been used probably 10 times max. Its not a cord problem..perhaps its the control?
This model has very cheap pots. What really happens is the center pin on the pot breaks leaving the wiper that rides on the carbon track to lift, causing this problem. Use caution as this condition continues the pot will go bad enough to send max volume to the system causing severe damage to the speaker, and maybe the listener. THE GREAT OZ.
Aug 08, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My JBL Eon15 g2 has a cracklin sound within the main component when the bass is turned up. How can I fix this?
Jun 21, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Damaged JBL Eon15 Tweeter
you can probably by a generic type of motherboard from a shop like JAYCAR lookem up on the net ]
May 25, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON15 PA Speaker problem
check the wire terminals under the cone by the spider and make sure that they are both still connected
Apr 16, 2009 | JBL GTO Series RLC Amplifier Accessory -...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I have jbl eon15 g2 which recently started to crackle when adjusting the levels. Recently that noise stopped, but when I raised it to high level (not out ordinary for the last 7 years) the sound cut out! I...
Open up the unit and clean the gain/volume control using an electronic swithc cleaner spray. Make sure that the cleaner contains a lubricant as well. That should resolve the problem. If not, update this with any changes in behavior.
Dan
Jul 03, 2008 | Audio Players & Recorders
Nov 25, 2006 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON15 G2 Main / Stereo Speaker Logo
153 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
