Question about Dishwashers
WHIRLPOOL DISHWASHER MODEL DUL200PKT1 WON,T DRAIN AFTER CYCLE IS COMPLETE.
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: Whirlpool dishwasher will not start
I have a quiet partner I and it is doing the same thing!
I have only had it for 3 months. It did it once before, then after about a week, I tried it again and it worked fine?
I can't find my warranty anywhere. I bought it at Lowes.
Does anyone have any kind of solution? Looks like it is a common problem.
Posted on Aug 09, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
  • 117 Answers
SOURCE: whirlpool dishwasher won't start
Your dishwasher has one door switch and the dishwasher will not operate if this switch is not working. So you are right!
Posted on Feb 25, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
Washer won't drain.
It is possible that your lid switch is defective. Bypass the switch and try again-Please unplug your machine while you bypass switch. If it still does not drain the I would suspect your timer.
Lid switch Part# 3949247
Timer Part# 3955651
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
Dishwasher repair
without model unablr to look up exact unit, but in genreral, either ther is a blockage/clog in oyour drain line not alowing complete drain of cycle, as far as never really washing, i would look into perhaps a faulty/ sloppy door switch assembly. if for some reason the dorr latch "loses contact" the machine will take that as someone openig the door and thus stopping from proceding in cycle.with complete model umber i may bbe able to assist further
Dec 30, 2008 | Dishwashers
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
