Question about Garden
Two years ago, my mower (cub cadet lt1042) wouldn't start. Replaced the solenoid switch and it worked the rest of that summer and the first half of last summer. The middle of last summer, I mowed part of my yard, shut it off, and then it wouldn't start again. It would crank, but not catch. I didn't have money to fix it, so I let it sit through the winter. Now, it will not even crank. I turn the key to start, and it does nothing. The battery was checked and is good. I replaced the spark plug and air filter and nothing. Oil level is good. What would make this stupid thing not want to start? Would replacing the ignition switch help?
    President:
  • 3,074 Answers
Hard to say, I would make sure the inline fuse is good, then use a vehicle and jump start the mower. I am sure you know how to ensure the mower is ready to start, so we won't cover the pto,brake,etc. Good Luck Tim
Posted on Mar 26, 2011
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Troubleshooting cub cadet LT1042 safety shutdown system
knowing the problem would help cranking but not starting the brake pedal has a switch there is a switch in the back on the trans one on the seat
May 12, 2012 | Cub Cadet Garden
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a cub cadet LT1042 and it is 3 years old...we have replaced the pto 2 times and replaced the belt 7 times what is the deal
You have to have something rubbing under there that isn't supposed to be, crawl under the tractor and watch the belt go around by hand, if you can turn it. Maybe see what is frozen up, in the wrong place, Gotta be a belt guide is rubbing or a pulley is not spinning. The PTO should last 20 years, all i can think is they got it too tight to start, .010" min, that is tight, and you must be in Florida picking up a lot of sand? If it was under any kind of warranty, I would raise a big stink about it. Those PTO's are not cheap. And the belt has got to be $20. I wouldn't go to a dealer for the belt, unless it is really special, just match it up at the auto parts store, for half the price of dealer. Hope this helps.
Jun 18, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
