Question about Briggs & Stratton Garden
I need to know the over head vave setting for the intake and exhaust on a 17.5hp Briggs & Stratton vertical shaft, single stroke lawn mower.
  • 252 Answers
Hi pauly46 here
set piston to tdc compression stroke then run it down the bore a 1/4 inch
set the tappetts to inlet the bottom valve ( alloy push rod ) to a tightish 0.004" and set the
ex valve the top one ( steel push rod ) to 0.005"
setting at 1/4 pst tdc eliminates decompressor from upsetting valve clearance seting
cheers pauly46
Posted on Mar 27, 2011
Which valve is the intake valve on a 17 hp briggs engine?
look at the valve s one is smaller than the other one this is the intake the big one is the exhaust valve
Jun 11, 2014 | Briggs AND Stratton Intek Briggs &...
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
I have a 2010 MTD Yard machine 21 inch snow thrower {123cc} and it broke a valve tappet bolt.I need to no were to set the intake and egzaust valves clearance.Thanks!
I can give you Briggs and Stratton figures for valve clearances of an engine this size. You may have to experiment a little till it runs right. ...you can adjust the intake valve (when it is closed) while the exhaust is open and adjust the exhaust valve (when it is closed) while the intake is open if you can tell...or ya can adjust them when the piston is at TDC on compression stroke (both valves closed). Intake: .004"-.006" Exhaust .004"-.006" (Vertical crankshaft)....for horizontal crank .004"-.006" Intake.....Exhaust is .006"-.011" Hope this helps . Here is a briggs engine specs chart..can';t find the Chinese engine listed anywhere http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Jan 21, 2011 | Garden
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
15.5 intek pushrods whitch one is for the intake vavle ?
Intake is aluminum, exhaust is steel. Set valves 1/4" past top dead center on compression stroke (both valves closed), intake (bottom) .003-.005, exhaust .005-.007
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Hard to start 18 hp briggs &stratton
cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Jun 21, 2009 | Briggs & Stratton Garden
Garden Logo
242 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
