Question about Garden
I don't know exactly how the deck and drive belts go on.
    President:
  • 3,074 Answers
You did not state what type of mower, hope its a Craftsman but here is a website. Tim
http://www.ehow.com/how_5151371_replace-belt-craftsman-riding-mowers.html
Posted on Mar 26, 2011
Is there a way to tighten the belt?
Don, there is usually a spring loaded tensioner to do this, the belt may be stretched and needs replaced, or some pulleys actually are now wear items and may need replaced. Check the video links below, some models are adjustable.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mower belt tensioner repair question to the Garage Gang
http://support.mtdproducts.com/app/answers/detail/a_id/563/~/deck-drive-belt-tension-adjustment---riding-mower-(step-thru)
Tightening the belt on John Deere L110 Tractor
Mowing Deck Belt Replacement On Husqvarna LR12 Lawn Tractor
Apr 20, 2016 | Garden
How do I replace the drive belt on a john deere 265? There doesn't seem to be a clear answer anywhere. Please help
you can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Aug 03, 2014 | John Deere Service Repair Manual 240 260...
John deere 855-70 manual
On ALL Deere riding lawn mowers, 1st, position the deck under the tractor. Depending on the belt drive: either PTO (the yellow button on the dash panel), or tension engaged-(a lever on the right side of the operator\'s seat), you loop the drive belt from the front of the deck to the pulley, always in the lower front area of the tractor\'s engine. If it has "beltguards" too close to the pulley, you must loosen the retaining bolt for the guard, it will allow the belt to squeeze by and onto the pulley. Then, 2nd but don\'t forget to retighten after slipping the belt on, push the "Deck heighth" lever fwd to drop the deck "hangars" at the rear of the deck into position to "pin" the eyelets with the supplied pins, washers and keepers: usually a cotter pin or a lynchpin that inserts thru a hole on the smooth bolt-pin. The easy part\'s over, but don\'t panic. 3rd, lift the front of the deck onto a block, allowing a heighth to apply the "adjusting rod" into the front of the mower chassis. Screw the retaining nut onto the threaded (long bolt) and remove the block. You\'re done. Next, and very important, RAISE & LOWER the deck, engage the belt tension, (here you may have to clear the area and start the engine to engage the PTO drive, if it\'s electronically controlled belt-drive), this assures nothing is "misaligned" or improperly positioned. Now, if the machine is on a flat surface, lower the deck to a point just above the ground and measure the distance in four (4) corners of the deck and record the ht. Make the adjustments to LEVEL the deck. Now you\'re ready to start the engine from the operator\'s seat, slightly increase the engine from idle to 1/4 throttle speed so that engaging the drive belt won\'t kill the engine. Ensure the belts run smoothly, the blades turn, and the engine doesn\'t "bog". Lower the deck to a desired cutting ht., now MOW the grass!
Jan 28, 2014 | Garden
Treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Jul 18, 2012 | Reebok Exercise & Fitness
How to change drive belt on craftsman ltx1000 18hp kohler
Find out the driver belt's partnumber. If you don't have the manual call Sears and tell them the model numberor look it up online. Clean out theunderside of your mower's deck, making sure there are no leftover pieces fromyour old belt still stuck inside. Findyour mower's tensioner, which keeps the pulleys in place, and loosen it (thisusually involves loosening a single bolt). Then slide the pulleys closertogether so that you can fit the belt over them more easily. Arrange the driver belt over the pulleys (youshould refer to your user manual for the exact configuration of the belt overthe pulleys, since this will vary depending on the specific model of your lawnmower) Tighten the tensioner back up,leaving only about a finger's width left of play in the belt.
Jul 03, 2012 | Garden
Model no. 917257660 need belt size for drive and deck
The part number for the drive belt is: 140294 the size is Length: 82 1/4", Width: 1/2", Type: Covered
The part number for the mower deck is: 140067 the size is Length: 82 1/2", Width: 1/2", Type: Covered
They are very similar belts so don't get them mixed up the springs on the clutch pulleys may not be able to compensate for the slight difference.
Good luck, if you find this helpful please vote yes. Thank You!!
May 11, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
MTD JE145H cutting deck keeps throwing belts
Usually the reason a mower deck is throwing its belts is there is a bearing that is starting to sieze up in one of the quill assemblies, which is the assembly that the blade is attached to . Either that or one of the belt tensioner pulleys is starting to go bad, easiest way to check this is remove the drive belt, take off the cover over the tension belt and remove that belt know check all moving parts for tightness or excessive looseness. Hope This Helps You Don
Dec 02, 2009 | Garden
I have a sony shelf system with combination cd and cassette - bel
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact:
> Lay it out flat on the table
> Pinch it at both ends & straighten the belt but don't stretch it.
> Measure the length & then double it and choose or we will recommend
a size about 3-5% smaller.
Old belt too far gone to measure:
> Just use a piece of string and thread it temporarily in place of where the belt goes.
> Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number.
If your belt has a round or square cross section, please give us the thickness as well. We can assist
you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
Jan 18, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
