Question about Graco Lajobi Kendal Convertible Crib
Trying to put together Freeport convertible crib. In figure one where should the barrel nut be placed at the top of back rail? Should there be a pre-drilled hole to place the barrel nut into, like the hole that is pre-drilled for the bottom?
  • 396 Answers
Yes and it should be under the top edge of the rail so it isnt visible when the
crib is assembeled. There should be a predrilled hole for the barrel nut to fit up into.
Posted on Mar 27, 2011
  • branann9010 Jun 24, 2011
    I have a freeport crib and i cant seem to find the pre-drilled hole either!
I HAVE LOST THE ALLEN WRENCH FOR THE CRIB AND I AM TRYING TO REPLACE IT.. CAN SOMEONE TELL ME THE SIZE PLEASE
Posted on Aug 19, 2012
Thank god!! I was about to drill my own hole when i found the predrilled hole on the BACK . In the picture it shows underneith but it is in same location on the back.
Posted on Aug 09, 2012
Instruction Manual for a Graco freeport 4-1 Convertible crib
What is the intruction to put the crib together i lost the papers that it go to
Apr 01, 2012 | Graco Blakely 4-in-1 Crib, Cherry
Apparently the company, RT cribs went out of business. we need the toddler rails to convert from a crib to toddler bed for our classic emma convertible crib model 88EM.
We bought the rails (in case that should happen) but it came with no directions, screws, etc. and we can't figure out how to put it together.
Have you had any luck?
Aug 07, 2011 | Toys
I bought a kinderkraft crib used and it came with the hardware, but no instruction manual. Can I find assembly instrutions online?
  • I can tell you how to assemble it.
  1. Place an insert nut into the top of the stationary rail.
  2. Place another nut into the bottom of that same rail.
  3. Flip that rail over and put another nut into the top and bottom of it the same as you just did.
  4. Now stick a two bolts into one side of the headboard.
  5. Stand up the headboard and twist them bolds from the headboard into the stationary rail.
  6. Now you want to twist two bolts through the secondary headboard and through the other side of the stationary rail. Make sure not to tighten them bolts up to much yet.
  7. Now put the mattress support inside the crib.
  8. Take four bolts into the top holes that are pre-drilled in the slat on the headboard and then on through to the mattress support.
  9. Do the same now with the other slat support for the headboard.
  10. Now do the same with the two remaining slats for the secondary headboard.
  11. Now tighten all the bolts real well.
  12. Put the crib on it's side.
  13. Now your gonna stick the canisters into the legs. Tap them in with a hammer if they are a bit stubborn.
  14. Now slide the rubber off of the lower side bracket.
  15. Hold the front drop rail so that the push plate faces away from the crib.
  16. Now slide that front drop rail on the tracks until it is all the way in the crib and then reinstall the rubber stoppers.
  17. Now put the crib on it's casters and go over the crib and give it a once over and make sure everything is secure and tight.
  18. Crib is ready to use now.
Regards, Tony
May 02, 2011 | Toys
I have no instructions for the Graco Freeport Convertible Crib....I would like to put this thing together...
The Graco website is pretty good for manuals, try there for your particular model the label is on a leg or inside one of the ends.
Jan 22, 2011 | Graco Baby Gear
I lost my instruction manual and trying to figure out how to convert the crib to a toddler bed. It is a summer infant carters casual convertible crib.
I have lost the nuts and bolts to put the Carter's convertible crib model #1101CC together. Does anyone know how to get their hands on a set? The bed is no longer for sale.
Dec 20, 2010 | Toys
2002 Graco crib instructions . i bought a used 2002 crib and I need to know how to put it together.
ok first thing first ,  some graco cribs and other products from 2002 -2010 are being recalled , so what crib model do you have? second , putting together a crib is very easy , . First , take the head board and stand it up , next find the side railings and one by one put the screw thru the rail and into the headboard , hold it in place untill it is where it needs to be , then put the second railing on , the screws should go thru the rail and into the headboard with the headboard in back of the rails, after the rails are secured then hold the foot board in place untill the screws are fastened into the rails as well , after you do this , then go around and make sure all the screws are tightned, then take the mattress spring and place it inside the setup rails and screw it unto the places alotted for the screws , then after this , place the matress inside and your done....if this doesnt help , please email me at konmon52@aim.com and tell me which model it is
Nov 19, 2010 | Graco Baby Gear
Graco - Freeport 4-in-1 Fixed-Side Convertible Crib comes with no instructions! how do i put it together?
The instructions are in an envelope attached to the springs (the thing under the mattress)
Nov 15, 2010 | Graco Baby Gear
Barrel nuts busted for toddler bed side-rail.
JUST BOUGHT 1 PACK OF 4 BARREL NUTS FOR STORKCRAFT CRIB AT CANADIAN TIRE FOR $3.59. WORKS GREAT!
Jan 09, 2009 | Storkcraft Baby Rochester Crib
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
How to convert crib to bed
I have the opposite problem - I can put it together as a toddler bed. The trick with that is that you put one of the long screws through both the hole at the SHORT end of the toddler bed side AND the metal flange from the springs into that end of the crib. The other long screw goes through the raised end of the toddler side into the end of the crib - where the child's head would be.
Is there supposed to be a plastic piece at the top of both ends of the crib on the side that does NOT go up and down? I can't seem to figure out how to put the crib side on.
Nov 03, 2007 | Childesigns Bellmont Crib
Graco Lajobi  Kendal Convertible Crib Logo
819 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
