Question about Canon Pixma MP500 All-In-One InkJet Printer
I have a cannon mp550 printer. I managed to make it print grayscale but it uses other colors too. I want it to print just using pgbk ink only but I don t know how.
    President:
  • Canon Master
  • 1,447 Answers
Problem on your black cartridge.Change it and buy new one.Fix your problem.
Posted on Mar 26, 2011
I have the same issue. I only print in black and never in color. On the print menu of the computer, I have to change it to grayscale every time I make a copy. Where I have a choice of Safari/Color Matching/Layout/Quality and Media, choose Quality and Media, then click on the grayscale printing box. If anybody knows how to make that a default, I would be very happy!
Posted on Oct 14, 2012
I want to print only using black and grey ink is this posable on the cannon MG5220 printer?
I don't know this specific model but on most print drivers there is a grey scale option undr color management.
Sep 21, 2014 | Cannon Office Equipment & Supplies
My PGBK ink cartridge is not printing. I just replaced it. Everything else is working fine. I have done several cleaning jobs on it and the test prints that I print don't even show PGBK or the black...
the PGBK ink cartridge might not be getting a good connection you might have to remove it and check the connections or clean the connection bars
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 21, 2011 | Canon Pixma iP4500 InkJet Printer
Cannon pixma ip3300 is not printing in black only color, (windows 7)
Does your blank ink cartrdige filled with ink?
Or before you print Click on the Properties button. Click the Color Tab\Print in Grayscale\Black ink only
Mar 18, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
I have set the Canon MP560 printer to print grayscale (black and white) but it still uses the color cartidges, apparently to periodically clean the nozzles so they will be able to print when needed. So I...
Canon has made there printer this way to SAVE on your black in and also to lubricate the print heads and other technical reasons.
To be honest I do not think its in your best interest to override the settings on this print due to the cause of damage to the print head and other sorts of failure.
There are chip re setters and other forms of ways to trick the system, These Void the warranty and thus Canon does not allow for this type of compromise to save ink. the best thing you can do here is purchase a ink kit with a chip that uses a contentious flo system to save you on ink purchases and money.
Here is a link to a example http://www.amazon.com/FantasyBuy-Bulk-Continuous-Ink-System/dp/B002T046TU
Good luck with your printer I hope this is a solution that best suites your needs to save money.
Nov 30, 2010 | Canon Office Equipment & Supplies
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Color toner used up even though I selected grayscale
Selecting grayscale only will also make use of your color. when u select grayscale, look under the print options and select black cartridge only and for more economic printing, use fast draft or draft printing.
Jun 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
414 people viewed this question
old marine
old marine
