Brand new Ricoh Aficio SPC232DN printer. SC 397 error code, have to power off/on, prints 1-2 jobs, then error code again.
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP 1600 Le error code sc 322 occured during print job how do i clear it
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Jan 12, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
885 people viewed this question
k24674
jasbo
jasbo
